Streaming audio via BT with bluetooth tracker enabled
Hi there!
I would like to stream audio to my BT speaker. The only problem is that I have enabled bluetooth_tracker and eq3btsmart components. So I start to stream the music, but after a while sound is being deformed, as components start to use BT.
Is there any way to make them cooperate with streaming? Or is there a way in which I could use external BT dongle to stream the music and internal adapter for HA?
Edit:
Yes, it is possible. bluetoothctl allows to select controller that we are using. HA automatically uses RPI’s built-in adapter
