Streaming updates/ Websockets errors on update to 0.34
Was the streaming updates button removed from the UI in 0.34? I ask because I’m no longer seeing it on mine since the upgrade. It appears that I am still seeing updates reflected in sensors and I don’t see any specific errors, but I am getting a number of websocket errors from the new websocket api:
16-12-04 13:00:00 homeassistant.core: Error doing job: Future exception was never retrieved
  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/websocket_api.py", line 246, in _forward_event
    self.send_message(event_message(iden, event))
  File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/websocket_api.py", line 221, in send_message
    self.wsock.send_json(message, dumps=JSON_DUMP)
  File "/home/hass/deps/aiohttp/web_ws.py", line 169, in send_json
    self.send_str(dumps(data))
  File "/home/hass/deps/aiohttp/web_ws.py", line 156, in send_str
    self._writer.send(data, binary=False)
  File "/home/hass/deps/aiohttp/_ws_impl.py", line 354, in send
    self._send_frame(message, WSMsgType.TEXT)
  File "/home/hass/deps/aiohttp/_ws_impl.py", line 333, in _send_frame
    self.writer.write(header + message)
  File "/usr/lib/python3.4/asyncio/selector_events.py", line 898, in write
    self._buffer.extend(data)
BufferError: Existing exports of data: object cannot be re-sized
16-12-04 13:03:02 homeassistant.core: Error doing job: Future exception was never retrieved
The sidebar menu entry has been removed, it is no longer possible to disable streaming updates. When an error occurs a toast will show up in the bottom left of the screen.
Those errors are, uhm, interesting. Haven’t seen them before.
Today I learned when it’s time to be concerned. :laughing:
I put in an issue for this. Release docs didn’t mention the missing toggle, perhaps that should be added. Came as a bit of a surprise to me and a few others.
I’m also losing connection in the UI and I added my notes to another user having the same problem.
I’m having the same problem as in the last issue. Frontend: Connection lost. Reconnecting. I don’t see any errors however in the log-file. If there is anything I can do to help, let me know.
You should comment on the Issue by clicking on the link. That way whomever is working the problem can be aware of how many users are affected without having to check the forums.
Done. I’ve added my comment.
I have the same errors
16-12-05 10:17:33 homeassistant.core: Error doing job: Future exception was never retrieved
  File "/home/hass/.homeassistant/deps/aiohttp/web_ws.py", line 169, in send_json
  File "/home/hass/.homeassistant/deps/aiohttp/web_ws.py", line 156, in send_str
  File "/home/hass/.homeassistant/deps/aiohttp/_ws_impl.py", line 354, in send
  File "/home/hass/.homeassistant/deps/aiohttp/_ws_impl.py", line 333, in _send_frame
16-12-05 10:17:33 homeassistant.components.sensor.statistics: variance requires at least two data points
16-12-05 10:17:33 homeassistant.components.sensor.statistics: mean requires at least one data point
16-12-05 10:17:33 homeassistant.components.climate.generic_thermostat: Unable to update from sensor: could not convert string to float: 'unavailable'
16-12-05 10:17:37 homeassistant.core: Error doing job: Future exception was never retrieved
16-12-05 10:18:00 homeassistant.core: Error doing job: Future exception was never retrieved
16-12-05 10:18:05 homeassistant.core: Error doing job: Future exception was never retrieved
16-12-05 10:18:27 homeassistant.core: Error doing job: Future exception was never retrieved
Did you add your comments to the issue?
Update - fix is upcoming:
