I’ve successfully flashed Tasmota-lite firmware on a cheap Geeni Wi-Fi bulb. I’ve installed the MQTT Broker on my rPi/Hass install and configured MQTT on the light bulb. I’ve also run SetOption19 1 on the Tasmota light bulb. It appears that the bulb is successfully connecting to Hass, and the MQTT broker sees the bulb connecting - however, I can’t add the device in Home Assistant, it’s as if the MQTT broker sees the connection but doesn’t think it’s an actual device. Wondering what I’m doing wrong. I enabled auto-discovery via the GUI when I installed the MQTT Broker. Logs below:
Tasmota light bulb:
00:30:29 WIF: Connecting to AP1 Peters2.4 in mode 11N as Geeni_Light_1-2020...
00:30:34 WIF: Connected
00:30:34 HTP: Web server active on Geeni_Light_1-2020 with IP address 192.168.50.28
00:30:35 MQT: Attempting connection...
00:30:35 MQT: Connected
00:30:35 MQT: tele/Geeni_Light_1/LWT = Online (retained)
00:30:35 MQT: cmnd/Geeni_Light_1/POWER =
00:30:35 MQT: tele/Geeni_Light_1/INFO1 = {"Module":"Geeni-1050-WW","Version":"8.1.0(lite)","FallbackTopic":"cmnd/DVES_4A87E4_fb/","GroupTopic":"cmnd/tasmotas/"}
00:30:35 MQT: tele/Geeni_Light_1/INFO2 = {"WebServerMode":"Admin","Hostname":"Geeni_Light_1-2020","IPAddress":"192.168.50.28"}
00:30:35 MQT: tele/Geeni_Light_1/INFO3 = {"RestartReason":"External System"}
00:30:35 MQT: stat/Geeni_Light_1/RESULT = {"POWER":"OFF"}
00:30:35 MQT: stat/Geeni_Light_1/POWER = OFF
MQTT Broker Logs:
[08:23:58] INFO: Setup mosquitto configuration
[08:23:58] WARNING: SSL not enabled - No valid certs found!
[08:23:58] INFO: Found local users inside config
[08:23:59] INFO: Initialize Hass.io Add-on services
[08:23:59] INFO: Initialize Home Assistant discovery
[08:23:59] INFO: Start Mosquitto daemon
1580477039: mosquitto version 1.6.3 starting
1580477039: Config loaded from /etc/mosquitto.conf.
1580477039: Loading plugin: /usr/share/mosquitto/auth-plug.so
1580477039: |-- *** auth-plug: startup
1580477039: ├── Username/password checking enabled.
1580477039: ├── TLS-PSK checking enabled.
1580477039: └── Extended authentication not enabled.
1580477039: Opening ipv4 listen socket on port 1883.
1580477039: Opening ipv6 listen socket on port 1883.
1580477039: Opening websockets listen socket on port 1884.
1580477039: Warning: Mosquitto should not be run as root/administrator.
1580477043: New connection from 172.30.32.1 on port 1883.
1580477044: Socket error on client <unknown>, disconnecting.
1580477044: New connection from 172.30.32.1 on port 1883.
[INFO] found homeassistant on local database
1580477044: New client connected from 172.30.32.1 as auto-D650768A-81D3-DB6C-9C0A-582560E414CF (p2, c1, k60, u'homeassistant').
1580477046: New connection from 192.168.50.28 on port 1883.
[INFO] found darren on local database
1580477047: New client connected from 192.168.50.28 as DVES_4A87E4 (p2, c1, k30, u'darren').
And here’s my autodiscovery proof (I think):
And my MQTT config on the Tasmota device:
