Struggling with command_line switch
I am trying to setup a simple switch to call either python or a shell script. Everything I try I have ended up with an invalid config. I can’t figure out what I am doing wrong, is it something with the user / virtual env?
I installed HomeAssistant on a raspberry pi following these instructions: https://home-assistant.io/docs/installation/raspberry-pi/
configuration.yaml:
switch:
platform: command_line
switches:
PC_Relay_Switch:
command_off: “sh /home/homeassistant/.homeassistant/test.sh”
Failed config
switch.command_line:
switches: [source /home/homeassistant/.homeassistant/configuration.yaml:75]
PC_Relay_Switch: [source /home/homeassistant/.homeassistant/configuration.yaml:76]
command_off: sh /home/homeassistant/.homeassistant/test.sh
Successful config (partial)
looks like no caps allowed in the switch name.
In my switches.yaml I have…
- platform: command_line
  switches:
    backup_cmd:
      command_on:  bash /home/pi/.homeassistant/shell_scripts/backup_config.sh
      command_off: bash /home/pi/.homeassistant/shell_scripts/backup_config.sh
So I would try bash not sh also confirm that homeassistant user can execute the bash file.
or as a shell_command
backup_config: “bash /home/pi/.homeassistant/shell_scripts/backup_config.sh”
yep all names have to lowercase and no spaces, only friendly names can have spaces and capitals :slight_smile:
