Hey,
Have been spending now 2 nights behind this issue, tried many approaches yet I still cannot figure out what I need to do. Hope that one of you could point me into the right direction please.
I am getting the following JSON back after an API request:
"preferredNextApiRequestAt": {
"secondOfHour": XXXX,
"epochTimeUtc": XXXXXXXXXXX
"status": 0,
"iLastPredictionGenerationEpochTime": XXXXXXXXXX,
"weather_source_text": "Kurzfristig (3 Tage): Powered by <a href=\"https://www.weatherapi.com/\" title=\"Free Weather API\">WeatherAPI.com</a> und Langfristig (10 Tage): Powered by <a href=\"https://www.visualcrossing.com/weather-data\" target=\"_blank\">Visual Crossing Weather</a>",
"datalinename": "Germany > L",
"data": {
"20230908": 35.574,
"20230909": 35.474
I need to take the two numbers (35.574 and 35.474) into two sensors. I cannot just call the number descriptors as that string (here: 20230908 and 20230909) change every day, so I thought I need to point to the numbers I want via a list The below is my YAML code. This one does not work, neither the many dozen other approaches I took. Likely this is really easy, but I am stuck…
Any help/hint/tip is highly welcome! Thank you!
rest:
- scan_interval: 86400
resource: "MY API CALL"
- name: "Solarprognose heute"
value_template: "{{ value_json.data[0]['value'] }}"
- name: "Solarprognose morgen"
value_template: "{{ value_json.data[1]['value'] }}"
