Stuck at "preparing home assistant" on odroidn2+ (No such image: ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4)
I got some errror on my odroird n2+ and it diddn respond,
so i connectet it and updated petitboot and reflashed the eMMC with the latest image, following this guide ODROID - Home Assistant
but after 1-2 hours in “Preparing Home Assistant” nothing happens and the error log says
““23-02-13 22:03:01 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-02-13 22:03:31 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/odroid-n2-homeassistant:landingpage to ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4
23-02-13 22:03:31 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/odroid-n2-homeassistant with tag 2023.2.4.””
when i loook at the observer port it says
“Home Assistant observer
Supervisor: Connected
Supported: Unsupported
Healthy: Unhealthy”
i replaced the eMMC with an SD car and tried again and now i get
" Home Assistant observer
|Supervisor:|Connected|
|Supported:|Supported|
|Healthy:|Unhealthy|"
23-02-14 07:24:58 ERROR (SyncWorker_2) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4/json: Not Found (“no such image: ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4: No such image: ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4”)
Is the error because of my Odroid? or is it from home assistant? What can i do? Thank you
i asked at the Odroid forum and they say nothing wrong with hardware,
so tried again, used Elena batcher, and this time tried another network and router, and still problem… this is wha i get
![Home Assistant logo](http://homeassistant.local:8123/landingpage/static/logo.svg)
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[11:39:02] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[11:39:02] INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
23-02-15 11:39:04 INFO (MainThread) [__main__] Initializing Supervisor setup
23-02-15 12:39:04 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: odroid-n2
23-02-15 12:39:04 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2023.01.1
23-02-15 12:39:04 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-02-15 12:39:04 INFO (SyncWorker_0) [supervisor.docker.interface] Cleanup images: ['ghcr.io/home-assistant/aarch64-hassio-supervisor:2022.12.1']
23-02-15 12:39:04 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
23-02-15 12:39:04 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-02-15 12:39:04 INFO (MainThread) [__main__] Setting up Supervisor
23-02-15 12:39:04 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-02-15 12:39:05 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-02-15 12:39:05 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-02-15 12:39:05 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-02-15 12:39:05 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-02-15 12:39:05 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-02-15 12:39:05 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-02-15 12:39:05 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-02-15 12:39:05 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-02-15 12:39:05 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-02-15 12:39:05 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-02-15 12:39:05 INFO (MainThread) [supervisor.host.services] Updating service information
23-02-15 12:39:05 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-02-15 12:39:05 INFO (MainThread) [supervisor.host.network] Updating local network information
23-02-15 12:39:05 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-02-15 12:39:05 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-02-15 12:39:05 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.11.0
23-02-15 12:39:05 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1
23-02-15 12:39:05 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-02-15 12:39:05 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.07.0
23-02-15 12:39:05 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0
23-02-15 12:39:05 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-02-15 12:39:05 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_observer application
23-02-15 12:39:06 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0 - 172.30.32.6
23-02-15 12:39:06 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0
23-02-15 12:39:06 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-02-15 12:39:06 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-02-15 12:39:06 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/odroid-n2-homeassistant with version landingpage
23-02-15 12:39:06 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-02-15 12:39:07 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.5 / BootSlot A
23-02-15 12:39:07 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
23-02-15 12:39:07 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
23-02-15 12:39:07 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
23-02-15 12:39:07 INFO (MainThread) [supervisor.store] Loading add-ons from store: 68 all - 68 new - 0 remove
23-02-15 12:39:07 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-02-15 12:39:07 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-02-15 12:39:07 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-02-15 12:39:07 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-02-15 12:39:07 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
23-02-15 12:39:07 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-02-15 12:39:07 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
23-02-15 12:39:07 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-02-15 12:39:07 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
23-02-15 12:39:07 INFO (MainThread) [__main__] Running Supervisor
23-02-15 12:39:07 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-02-15 12:39:07 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
23-02-15 12:39:07 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
23-02-15 12:39:07 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
23-02-15 12:39:07 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
23-02-15 12:39:07 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
23-02-15 12:39:07 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-02-15 12:39:07 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-02-15 12:39:07 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-02-15 12:39:07 INFO (MainThread) [supervisor.host.info] Updating local host information
23-02-15 12:39:07 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/odroid-n2-homeassistant:landingpage to ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4
23-02-15 12:39:07 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-02-15 12:39:07 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/odroid-n2-homeassistant with tag 2023.2.4.
23-02-15 12:39:07 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-02-15 12:39:07 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-02-15 12:39:07 INFO (MainThread) [supervisor.host.services] Updating service information
23-02-15 12:39:07 INFO (MainThread) [supervisor.host.network] Updating local network information
23-02-15 12:39:07 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-02-15 12:39:07 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-02-15 12:39:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-02-15 12:39:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-02-15 12:39:08 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
23-02-15 12:39:08 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
23-02-15 12:39:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-02-15 12:39:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-02-15 12:39:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-02-15 12:39:08 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-02-15 12:39:08 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-02-15 12:39:08 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-02-15 12:39:08 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-02-15 12:39:08 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-02-15 12:48:48 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4/json: Not Found ("no such image: ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4: No such image: ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4")
23-02-15 12:48:48 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-02-15 12:49:18 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/odroid-n2-homeassistant:landingpage to ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4
23-02-15 12:49:18 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/odroid-n2-homeassistant with tag 2023.2.4.
23-02-15 13:03:44 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4/json: Not Found ("no such image: ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4: No such image: ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4")
23-02-15 13:03:44 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-02-15 13:04:14 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/odroid-n2-homeassistant:landingpage to ghcr.io/home-assistant/odroid-n2-homeassistant:2023.2.4
23-02-15 13:04:14 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/odroid-n2-homeassistant with tag 2023.2.4.
any suggestion?
another try with same? and other errors…
[19:41:33] INFO: Using udev information from host
[19:41:33] INFO: Starting local supervisor watchdog...
23-02-15 19:41:35 INFO (MainThread) [__main__] Initializing Supervisor setup
23-02-15 19:41:35 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
23-02-15 19:41:36 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: odroid-n2
23-02-15 19:41:36 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2022.12.1
23-02-15 19:41:36 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-02-15 19:41:36 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
23-02-15 19:41:36 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-02-15 19:41:36 INFO (MainThread) [__main__] Setting up Supervisor
23-02-15 19:41:37 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-02-15 19:41:37 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-02-15 19:41:37 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-02-15 19:41:37 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-02-15 19:41:37 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-02-15 19:41:37 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-02-15 19:41:37 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-02-15 19:41:37 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-02-15 19:41:37 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-02-15 19:41:37 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-02-15 19:41:37 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-02-15 19:41:37 INFO (MainThread) [supervisor.host.services] Updating service information
23-02-15 19:41:37 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-02-15 19:41:40 INFO (MainThread) [supervisor.host.network] Updating local network information
23-02-15 19:41:40 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-02-15 19:41:51 WARNING (MainThread) [supervisor.utils.whoami] Can't fetch Whoami data: Timeout
23-02-15 19:41:51 WARNING (MainThread) [supervisor.core] Can't adjust Time/Date settings: Can't fetch Whoami data: Timeout
23-02-15 19:41:51 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-02-15 19:41:51 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2022.11.0'>]
23-02-15 19:41:51 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.11.0
23-02-15 19:41:51 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-02-15 19:41:51 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.11.0 - 172.30.32.5
23-02-15 19:41:52 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2022.04.1'>]
23-02-15 19:41:52 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1
23-02-15 19:41:52 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-02-15 19:41:52 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1 - 172.30.32.3
23-02-15 19:41:52 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-02-15 19:41:52 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2022.07.0'>]
23-02-15 19:41:52 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.07.0
23-02-15 19:41:52 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-02-15 19:41:53 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.07.0 - 172.30.32.4
23-02-15 19:41:53 INFO (SyncWorker_0) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/aarch64-hassio-observer
23-02-15 19:41:53 INFO (MainThread) [supervisor.plugins.base] No observer plugin Docker image ghcr.io/home-assistant/aarch64-hassio-observer found.
23-02-15 19:41:53 INFO (MainThread) [supervisor.plugins.observer] Running setup for observer plugin
23-02-15 19:41:53 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-02-15 19:41:57 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-observer with tag 2021.10.0.
23-02-15 19:42:08 INFO (MainThread) [supervisor.plugins.observer] observer plugin now installed
23-02-15 19:42:08 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-02-15 19:42:09 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0 - 172.30.32.6
23-02-15 19:42:09 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2022.02.0'>]
23-02-15 19:42:09 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0
23-02-15 19:42:09 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-02-15 19:42:09 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0 - Host
23-02-15 19:42:09 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-02-15 19:42:09 INFO (SyncWorker_0) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/odroid-n2-homeassistant
23-02-15 19:42:09 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/odroid-n2-homeassistant found.
23-02-15 19:42:09 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/odroid-n2-homeassistant with version landingpage
23-02-15 19:42:09 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
23-02-15 19:42:09 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-02-15 19:42:09 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-02-15 19:42:09 INFO (SyncWorker_0) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/odroid-n2-homeassistant with version landingpage
23-02-15 19:42:09 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.5 / BootSlot A
23-02-15 19:42:09 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-02-15 19:42:09 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
23-02-15 19:42:10 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-02-15 19:44:29 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
stderr: 'Cloning into '/data/addons/git/a0d7b954'...
POST git-upload-pack (175 bytes)
POST git-upload-pack (244 bytes)
error: RPC failed; curl 56 OpenSSL SSL_read: Connection reset by peer, errno 104
error: 3992 bytes of body are still expected
fetch-pack: unexpected disconnect while reading sideband packet
fatal: early EOF
fatal: fetch-pack: invalid index-pack output
23-02-15 19:44:29 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/hassio-addons/repository due to
23-02-15 19:44:29 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / a0d7b954
23-02-15 19:44:29 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / a0d7b954
23-02-15 19:44:32 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://github.com/esphome/home-assistant-addon /data/addons/git/5c53de3b
stderr: 'Cloning into '/data/addons/git/5c53de3b'...
error: 2570 bytes of body are still expected
fatal: early EOF
23-02-15 19:44:32 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/esphome/home-assistant-addon due to
23-02-15 19:44:32 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / 5c53de3b
23-02-15 19:44:32 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / 5c53de3b
23-02-15 19:44:50 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://github.com/home-assistant/addons /data/addons/core
stderr: 'Cloning into '/data/addons/core'...
error: 7454 bytes of body are still expected
fatal: early EOF
23-02-15 19:44:50 ERROR (MainThread) [supervisor.store] Can't retrieve data from core due to
23-02-15 19:44:50 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / core
23-02-15 19:44:50 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core
23-02-15 19:44:50 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
23-02-15 19:44:50 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-02-15 19:44:50 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-02-15 19:44:50 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-02-15 19:44:50 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-02-15 19:44:50 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
23-02-15 19:44:50 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-02-15 19:44:50 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
23-02-15 19:44:50 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-02-15 19:44:50 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
23-02-15 19:44:50 INFO (MainThread) [__main__] Running Supervisor
23-02-15 19:44:50 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-02-15 19:44:50 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor.txt
23-02-15 19:44:51 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
23-02-15 19:44:51 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2023.01.1
23-02-15 19:44:51 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/aarch64-hassio-supervisor with tag 2023.01.1.
