Stuck on adding first device
My first ever attempt at using ESPHome with an ESP32 Devkit Type C is not working for me unfortunately. I’m trying to connect via USB from a Raspberry Pi 4 that runs Home Assistant via Docker, so I followed the instructions given at ’ Bonus: ESPHome Device Builder’.
The Dashboard is accessible at localhost:6052 but looking at ‘Show discovered devices’ shows nothing, and starting the ‘+ New Device’ process just leads to a ‘Connecting’ spinning display that goes nowhere.
lsusb shows a ‘Silicon Labs CP210x UART Bridge’ on Bus 001 Device 008, so something seems to be there.
How can I troubleshoot what the problem might be?
Thanks!
Michael
I take it ESPHome Builder is installed manually rather than as a Home Assistant Add-on?
This may have to do with set-up for the HA/ESPHome installation methods you’ve chosen.
If you drop a text file called test.yaml in the directory you specified as your config directory does it show up in your dashboard? And if so when you go to …> Install > Plug into Computer Running ESPHome… can you see the usb serial?
I have the ESPHome AddOn, and I’m getting the same problem (I’m using a Node-MCU just to play with). I know the UART is fine as I can program the Node-MCU using Arduino using the same port as was used by the ESPHome Web I/F. Unfortunately I have not yet figured out what the problem is however …
discovery only works on devices already running esphome and connected to network
you must first flash via usb.
new device >> continue >> empty configuration >> add name >> next >> edit >> modify the yaml >> save >> install >> “plug into this computer” >> select your device >> install
I was running everything from my Pi4 and it was probably too much with Docker and so on. I switched to a Windows laptop, installed esphome and then using the command line has been successful in compiling and installing things. I’m stuck on something else now but that’s a topic for a different post if needed. The learning curve is very steep for a noob :wink:
I suspect the learning curve would be much easier if you went with the Home Assistant Operating System and ESPHome as an App (previously add-on).
But people have varying needs for multitasking on their hardware.
