I have read various other queries on this but I just cannot get my trigger template to work with the trigger.from_state condition in the value template. I do not want to use this condition on other triggers I use in my automation so I can’t move it out of the trigger value template into the conditions section.
The trigger in the value template is meant to trigger lighting when the light sensor drops below a certain level but it triggers again when the sensor is already below the threshold when the sensor returns from an unavailable or unknown state. I only want it to trigger when the sensor level drops from a valid higher level across the threshold.
I must be making a mistake in the code but when the “trigger.from_state.state not in [‘unavailable’, ‘unknown’ ]” is in the trigger value template, it never triggers.
alias: Test trigger
description: ""
triggers:
- trigger: template
value_template: >-
{{ states('sensor.lightsensor_illuminance') | is_number and
states('sensor.lightsensor_illuminance') | float < 150 and
trigger.from_state.state not in ['unavailable', 'unknown' ] }}
conditions: []
actions: []
mode: single
You don’t get a trigger state object until after the trigger completes. i.e. after your trigger template is evaluated. So trigger.from_state.state will always be unknown in your template
Try this instead:
alias: Test trigger
description: ""
triggers:
- trigger: numeric_state
entity_id: sensor.lightsensor_illuminance
below: 150
conditions:
- condition: template
value_template: "{{trigger.from_state.state not in ['unavailable', 'unknown' ] }}"
actions: []
mode: single
Thanks I was not aware about the trigger state object.
Now that I am trying the way you suggested I am coming against another issue. The trigger.from_state.state is returning the previous numeric status of the sensor but where it has been offline it is returning nothing at all rather than the expected unavailable (or unknown).
If I looked at the previous state in “states” it was unavailable but this is not being returned. I have tried adding “None” and “none” and even “” but the test is never true.
If I change the test to a numeric function it works unless there is the nil return when I get the error message “Error: In ‘template’ condition: UndefinedError: ‘None’ has no attribute 'state’”
The exact code I am using is the trigger code suggested by Tom_I above. I have nothing else added as I do not want anything else to interfere with the trigger problem.
That error message implies the trigger object doesn’t exist or it does but has no properties.
How are you testing the automation?
Please post the automation’s trace when the sensor’s previous value is not a number. Download the trace file and copy-paste its JSON contents, ensuring its formatting is preserved.
The trace file’s details will help expedite a solution.
NOTE
If you need instructions for downloading and posting a trace file, they are available here.
I made a helper number and a test automation for this. I used the developer tools to set the value of the number to a string so I could test seeing not a number. It seemed to function as the OP described their use case. But there could still be issues because I didn’t test it extensively.
After hours of trying different things I seemed to have solved the issue.
I have modified the condition to:
{{trigger.from_state.state not in ['unavailable', 'unknown', null ] }}
It is the addition of the null without any quotation/apostrophe marks that makes it work. I could see the previous trigger state was null in the trace download. Using quotation/apostrophe marks on null similar to “unavailable” and “unknown” prevents the condition from working. I have no idea why one state needs quotation/apostrophe marks and the other states don’t.
Your condition contains a reference to trigger.from_state.state.
The condition I suggested contains a reference to trigger.from_state.state.
Both templates reference the exact same property of the trigger object.
Assuming the exact same testing scenario, it’s seemingly impossible for one version to report “None has no attribute state” but not the other version.
Pop this into the Template Editor and the result is not an error message but false.
{{ none | is_number}}
none is Jinja2’s representation for the null object.
The fact the trace revealed that trigger.from_state.state had a state property (with a value of null) casts suspicion on the earlier test that reported it did not even have a state property.
