Stuck on "Loading data" after updating to 0.63.1
been using 0.57 for a few months now without a hitch. Decided to upgrade to 0.63.1 and now I’m stuck on “loading data” page endlessly, both on my desktop and ios. My automations, homebridge are still working though. I’m a complete noob here, don’t even know where to start.
When you upgraded did you check the blog for the breaking changes for each upgrade between .57 to .63.1? That’s usually the cause of the frontend not loading. Also check the log file for errors.
Are you using a Broadlink IR Blaster? If so, you’ll need to make some changes to your YAML file(s)
I’m using a xiaomi IR blaster. Though automations and homebridge still works with the IR blaster. What kind of changes on the yaml?
They changed the syntax for the send and learn commands a bit. I forgot the syntax, but if you don’t change the syntax, the symptoms that you described above happens.
I think the change to 0.62 also affected xiaomi as well. My want to look up 0.62 to see all of the issues and check what the fix is for the xiaomi problem
