Here’s the inspect Windows
InsecureRequestWarning,
/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py:1004: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#ssl-warnings
That’s usually not a browser issue. It’s that HA isn’t starting correctly.
You need to look in your home-assistant.log file located in your config directory.
