Stuck with doorbell
Hi All,
So I have a 433mhz doorbell and I would like to integrate it will HA
This is how I have it configured
switch:
  - platform: rflink
    devices:
      aster_00f4_01: {}
and here you can see it’s being received by HA
2021-02-09 18:25:34 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {'id': 'aster_00f4_01', 'command': 'on'}
2021-02-09 18:25:34 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: ['switch.aster_00f4_01']
2021-02-09 18:25:34 DEBUG (MainThread) [homeassistant.components.rflink] passing event to switch.aster_00f4_01
The doorbell only sends an on command so it leaves the state as on.
How do you automatically turn the state to off?
If you configure it like a binary_sensor you can use the off_delay attribute:
binary_sensor:
   - platform: rflink
     devices:
       aster_00f4_01:
         off_delay: 5
You can configure other attributes too. More info in the documentation:
Is it sending on, ALLON, allon … etc as per the config guide? In whch case use @javicalle solution.
Thank you works great
What hardware do you use to communicate with 433?
Hardware -
1 x https://www.nodo-shop.nl/en/rflink-gateway/170-rflink-arduino-antenna.html
1 x https://www.nodo-shop.nl/en/home/191-rflink-wifi-koppelprint.html
1 x https://www.nodo-shop.nl/en/home/189-nodemcu.html
Software -
http://www.rflink.nl/blog2/
https://www.letscontrolit.com/wiki/index.php/ESPEasy
rflink is flashed onto the arduino and it receives the 433 sginals from the gateway board plugged in on top.
Then to make it wireless i use wifi board and nodemcu to act as a serial gateway for home assistant to connect to
Cool! Thanks!
