Trying to add Homekit support to my Home Assistant setup. When I add a simple homekit config to configuration.yaml HA can’t start.
If I start it manually (with hass command) it stucks on “Attempting install of HAP-python”. If try to install HAP-python from command line with pip3 install it stucks on installing pycryptodome
And finally, when I run
pip3 -vvv install pycryptodome
It stucks on
creating build/lib.linux-armv6l-3.5/Crypto/SelfTest/Signature/test_vectors/wycheproof
copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/ecdsa_secp256r1_sha256_test.json -> build/lib.linux-armv6l-3.5/Crypto/SelfTest/Signature/test_vectors/wycheproof
copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/dsa_test.json -> build/lib.linux-armv6l-3.5/Crypto/SelfTest/Signature/test_vectors/wycheproof
copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/ecdsa_test.json -> build/lib.linux-armv6l-3.5/Crypto/SelfTest/Signature/test_vectors/wycheproof
copying lib/Crypto/SelfTest/Signature/test_vectors/wycheproof/rsa_signature_test.json -> build/lib.linux-armv6l-3.5/Crypto/SelfTest/Signature/test_vectors/wycheproof
Skipping optional fixer: buffer
Skipping optional fixer: idioms
Skipping optional fixer: set_literal
Skipping optional fixer: ws_comma
How can I fix it?
P.S. I use Hassbian on my Raspberry B+
