If i enter my subdomain website home.website.com it does not go to the home assistant. I am confused with these lot of configurations. Which one to setup to make my subdomain home.website.com redirect to HA? Probably i missing some configuration or HA is confused with certificate from ngninx and cloud flare
My Duck DNS configuration
aliases:
- domain: home.website.com
alias: myhome.duckdns.org
domains:
- myhome.duckdns.org
lets_encrypt:
accept_terms: true
algo: secp384r1
certfile: fullchain.pem
keyfile: privkey.pem
seconds: 300
token: 1c3f41b4-1b3d-42c5-b1d1-8dca43cc07
Cloudflare CNAME setting
I also have certificate for wildcard *.website.com domain in cloudflare
Router setting
Port forwarded my Home assistant OS hosted local ip
local ip and port 8123
Local Ip and port 443
NGINX proxy HA addon setting
SSL certificate renewed
Configuration.yml file settings
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
alexa:
smart_home:
http:
base_url: https://home.website.com:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
