Hello, I’m vibe coding myself through a custom integration. yet I strive to understand the code generated. Here is the piece I stumbled over:
async def async_added_to_hass(self) -> None:
"""Run when entity is added to hass."""
await super().async_added_to_hass()
# Subscribe to temperature sensor state changes
self.async_on_remove(
async_track_state_change_event(self.hass, [self._temperature_sensor], self._async_temperature_changed, ))
# Get initial temperature
await self._async_update_temperature()
await self._async_control_heating()
I first figured the self.async_on_removeis wrong, as I want the integration to subscribe to temperature changes while it’s active, not just when it’s removed (this is how I interpret the call).
However, it does work as intended (temp changes trigger recalculation) and there is a piece of documentation here: Thread safety with asyncio | Home Assistant Developer Docs that seems to imply the same structure for subscribing to events.
Can anyone explain this to me and confirm that async_on_remove is indeed the correct way to subscribe to changes?
thx
