Heyhey team ModBus
ran into an issue, that kills my Home Assistant with ModBus.
I got a PV installation with a ModBus Smartmeter SDM630v2.
Those i integrated via this config:
modbus:
- name: modbus_1
type: serial
port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
baudrate: 19200
# baudrate: 9600
bytesize: 8
method: rtu
parity: N
stopbits: 1
delay: 0
message_wait_milliseconds: 45
timeout: 5
sensors:
## SM1
- name: sdm630_01_phase_1_line_to_neutral_volts
unique_id: sdm630_01_phase_1_line_to_neutral_volts
slave: 1
address: 0
input_type: input
precision: 2
data_type: float32
unit_of_measurement: V
device_class: voltage
state_class: measurement
- name: sdm630_01_phase_2_line_to_neutral_volts
unique_id: sdm630_01_phase_2_line_to_neutral_volts
slave: 1
address: 2
input_type: input
precision: 2
data_type: float32
Now for the second time in a few days my HA doesnÂŽt come up anymore. Logs (set ModBus to debug) is full of this:
2025-03-20 19:07:33.355 DEBUG (MainThread) [pymodbus.logging] Connecting to /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0:0.
2025-03-20 19:07:33.355 DEBUG (MainThread) [pymodbus.logging] Connecting comm
2025-03-20 19:07:35.730 DEBUG (MainThread) [pymodbus.logging] Connected to comm
2025-03-20 19:07:35.754 INFO (MainThread) [homeassistant.components.modbus.modbus] modbus modbus_1 communication open
2025-03-20 19:07:35.773 DEBUG (MainThread) [pymodbus.logging] recv: 0x1 0x4 0x0 0x34 0x0 0x2 0x30 0x5 0x1 0x4 0x4 0x42 0x15 0xac 0xa0 0x83 0x40 0x1 0x4 0x0 0x34 0x0 0x2 0x30 0x5 0x1 0x4 0x4 0x42 0x75 0x18 0xd0 0xf5
2025-03-20 19:07:35.774 DEBUG (MainThread) [pymodbus.logging] Processing: 0x1 0x4 0x0 0x34 0x0 0x2 0x30 0x5 0x1 0x4 0x4 0x42 0x15 0xac 0xa0 0x83 0x40 0x1 0x4 0x0 0x34 0x0 0x2 0x30 0x5 0x1 0x4 0x4 0x42 0x75 0x18 0xd
2025-03-20 19:07:35.774 DEBUG (MainThread) [pymodbus.logging] Frame check failed, possible garbage after frame, testing..
2025-03-20 19:07:35.775 DEBUG (MainThread) [pymodbus.logging] Frame check failed, possible garbage after frame, testing..
2025-03-20 19:07:35.776 DEBUG (MainThread) [pymodbus.logging] Frame check failed, possible garbage after frame, testing..
2025-03-20 19:07:35.777 DEBUG (MainThread) [pymodbus.logging] Frame check failed, possible garbage after frame, testing..
2025-03-20 19:07:35.778 DEBUG (MainThread) [pymodbus.logging] Frame check failed, possible garbage after frame, testing..
2025-03-20 19:07:35.780 DEBUG (MainThread) [pymodbus.logging] Frame check failed, possible garbage after frame, testing..
2025-03-20 19:07:35.781 DEBUG (MainThread) [pymodbus.logging] Frame check failed, possible garbage after frame, testing..
2025-03-20 19:07:35.781 DEBUG (MainThread) [pymodbus.logging] decoded PDU function_code(4 sub -1) -> ReadInputRegistersResponse(dev_id=0, transaction_id=0, address=0, count=0, bits=[], registers=[], status=1)
2025-03-20 19:07:35.781 DEBUG (MainThread) [pymodbus.logging] Frame advanced, resetting header!!
2025-03-20 19:07:35.781 DEBUG (MainThread) [pymodbus.logging] recv, unused data waiting for next packet: 0x1 0x4 0x4 0x42 0x15 0xac 0xa0 0x83 0x40 0x1 0x4 0x0 0x34 0x0 0x2 0x30 0x5 0x1 0x4 0x4 0x42 0x75 0x18 0xd0 0
2025-03-20 19:07:35.955 DEBUG (MainThread) [pymodbus.logging] recv: 0x1 0x4 0x0 0x34 0x0 0x2 0x30 0x5 0x1 0x4 0x4 0x42 0x18 0x8a 0xe0 0x9 0x13 old_data: 0x1 0x4 0x4 0x42 0x15 0xac 0xa0 0x83 0x40 0x1 0x4 0x0 0x34 0x
2025-03-20 19:07:35.956 DEBUG (MainThread) [pymodbus.logging] Processing: 0x1 0x4 0x4 0x42 0x15 0xac 0xa0 0x83 0x40 0x1 0x4 0x0 0x34 0x0 0x2 0x30 0x5 0x1 0x4 0x4 0x42 0x75 0x18 0xd0 0xf5 0xba 0x1 0x4 0x0 0x34 0x0 0
2025-03-20 19:07:35.956 DEBUG (MainThread) [pymodbus.logging] Frame check failed, possible garbage after frame, testing..
As HA no longer works i tried deactivating the SDM Meters and removed all the configured sensors. Unfortunately this does not solve the thing. Its definitely modbus as removing the modbus configâŠyou know
