Sum sensor states in apexcharts-card header
Rather that display the last sensor states in the header in this graph, which are: (0.1kWh, 0.5kWh, 0kWh)
I would like to display the sum of the sensor states for the period that are in the graph, which instead would be something like (37.5kWh, 5.9kWh, 0kWh).
Seems like the data_generator might be able to do this?
Here is my current config for the apexchart card:
type: custom:apexcharts-card
header:
  show: true
  title: Energy usage
  show_states: true
  colorize_states: true
show:
  last_updated: false
stacked: true
graph_span: 24h
span:
  start: day
  offset: '-1d'
series:
  - entity: sensor.total_mill_energy
    type: column
    group_by:
      func: diff
      duration: 1h
      start_with_last: true
  - entity: sensor.total_hot_water_energy
    type: column
    group_by:
      func: diff
      duration: 1h
  - entity: sensor.tesla_charging
    type: column
    group_by:
      func: diff
      duration: 1h
You could try duplicating the entities (ie. now 6 series), and having the group-by duration for the second set being “1d”. Then for the original 3 set “in_header” to false, and the new 3 set “in_chart” to false. I’ve not tried it, but easy to test at least.
@phio did you find a solution for this? I’m looking for the same kind of functionality.
I tried @michaelblight suggestion but it seems to be integrating all values taken through the day so the daily sum is something silly.
Yeah, I rebuilt the graphs in grafana :slight_smile:
Managed to get this working by duplicating the entities and putting them on a hidden yaxis.
experimental:
  color_threshold: true
header:
  show: true
  title: Consumption Yesterday v2
  show_states: true
update_interval: 1h
graph_span: 24h
span:
  start: day
  offset: '-48h'
yaxis:
  - id: cost
    min: ~0
    decimals: 2
    align_to: 0.05
  - id: consumption
    min: ~0
    decimals: 2
    opposite: true
    align_to: 0.1
  - id: hidden
    show: false
series:
  - entity: >-
      sensor.octopus_energy_electricity_xxxx_xxxxxxxx_previous_accumulative_cost
    type: line
    color: green
    yaxis_id: cost
    float_precision: 3
    opacity: 1
    stroke_width: 3
    unit: GBP
    show:
      in_chart: true
      in_header: false
      legend_value: false
    color_threshold:
      - value: -100
        color: cyan
      - value: 0
        color: lightgreen
      - value: 0.1
        color: orange
      - value: 0.2
        color: red
      - value: 0.3
        color: purple
    data_generator: |
      return entity.attributes.charges.map((entry) => {
         return [new Date(entry.from), entry.cost_raw];
  - entity: sensor.octopus_energy_electricity_xxxx_xxxxxxxx_current_rate
    type: line
    color: darkcyan
    yaxis_id: cost
    stroke_width: 1
    show:
      in_chart: true
      in_header: false
      legend_value: false
    color_threshold:
      - value: -100
        color: cyan
  - entity: >-
      sensor.octopus_energy_electricity_xxxx_xxxxxxxx_previous_accumulative_consumption
    type: column
    yaxis_id: consumption
    stroke_width: 8
    show:
      in_chart: true
      in_header: false
      legend_value: false
    color: grey
    color_threshold:
      - value: -100
        color: '#777777'
    float_precision: 3
    data_generator: |
         return [new Date(entry.from), entry.consumption];
  - entity: >-
    yaxis_id: hidden
    unit: GBP
    show:
      in_header: raw
      header_color_threshold: true
      in_chart: false
      name_in_header: false
    float_precision: 2
    color_threshold:
      - value: -100
        color: cyan
      - value: 1.5
        color: green
      - value: 2.3
        color: orange
      - value: 3
        color: red
      - value: 4
        color: purple
  - entity: >-
    yaxis_id: hidden
    color: grey
    show:
      in_header: raw
      header_color_threshold: false
      in_chart: false
      legend_value: false
    float_precision: 2
Nice graph! Couple of things might have changed in the OctopusDave integration:
entry.from is now entry.start
entry.cost_raw is now entry.cost
Offset: -24h was needed for me.
Hope that helps someone else avoid the debugging I did!
Hi, can anyone help me?
In the graph I can’t show the third column…
The sesor is sum and difference other sensor:
    sensors:
      deye_daily_load_consumption_completed:
        friendly_name: "Daily Load Consumption (Completed)"
        unit_of_measurement: 'kWh'
        value_template: '{{ states("sensor.deye_daily_production") |float(0) -
                            states("sensor.deye_daily_battery_charge") | float(0) +
                            states("sensor.deye_daily_battery_discharge") |float(0) +
                            states("sensor.deye_daily_energy_bought") |float (0)
the card:
apex_config:
  chart:
    height: 300px
graph_span: 7day
span:
  end: day
show:
  last_updated: true
header:
  show: true
  show_states: true
  title: ANDAMENTO GIORNALIERO
yaxis:
  - id: consuption
    min: ~0
    decimals: 2
    align_to: 0.1
    max: "|+5|"
series:
  - entity: sensor.deye_daily_energy_bought
    yaxis_id: consuption
    type: column
    color: rgb(84, 144, 194)
    show:
      datalabels: false
    group_by:
      func: diff
      duration: 1day
    statistics:
      type: state
      period: 5minute
    transform: return Number(x) * 1.0;
    unit: kWh
  - entity: sensor.deye_total_production
    type: column
    show:
      datalabels: false
    color: rgb(255, 155, 48)
    group_by:
      func: diff
      duration: 1day
    statistics:
      type: state
      period: 5minute
    unit: kWh
    float_precision: 2
  - entity: sensor.deye_daily_load_consumption_completed
    color: grey
    type: area
    group_by:
      func: max
      duration: 1day
    statistics:
      type: max
      period: 5minute
    show:
      in_header: raw
      name_in_header: true
      in_chart: true
      legend_value: true
    float_precision: 2
Thank you all
