Please share your feedbacks. Thanks.
Features
- Responsive Grid Layout: Define the number of columns and height per row.
- Domain-Aware Conditions: Each domain has intelligent predefined conditions like
if_any_on,if_all_idle,if_any_heating, etc. - Template-Backed Conditions: Use full Jinja templates for advanced logic in combination with default logic.
- Clock Support: Add a live-updating card showing the current time and date.
- Auto-Fill on First Use: Automatically fills in cards based on detected domains on first load.
- Fully Visual Editor: No YAML required. Add/edit cards, conditions, and templates via a clean UI.
- Jinja in Text: Use domain-specific count placeholders like
{{ on_count }},{{ heating_count }}or full backend-evaluated Jinja strings insidetextandsecondary_text. - Tap & Hold Actions: More Info, Navigate, URL, Perform Action, Toggle, Nothing β with full confirmation dialog support (HA native).
- Vacuum Popup with Input Select: Optionally display
input_selectentities (e.g., map selection) directly inside the vacuum more-info popup.
