Sun automation trigger not working
I have an automation controlling my covers if I go to sleep or the sunset (30 min after) happens. It run for the last few month without problem. But since the latest update to 2021.9.x it stopped working. The automation does not trigger anymore for sunset, the sleepmode trigger still works correct only the sunset does not trigger anymore.
Here is the full automation maybe someone can tell me what is broken or if that is a bug. Automation has been created with ui edior in Lovelace.
alias: Rollos runter wenn 30 Minuten nach Sonnenuntergang oder Schlafmodus an
description: ''
  - entity_id: input_boolean.sleepmode
    platform: state
    to: 'on'
  - event: sunset
    offset: '00:30:00'
    platform: sun
condition: []
  - choose:
      - conditions:
          - condition: state
            entity_id: sensor.window_kitchen_open_check
            state: geschlossen
        sequence:
          - service: script.turn_on
            data: {}
            entity_id: script.kueche_rollo_runter
      - conditions:
          - condition: state
            state: offen
        sequence:
            data: {}
            entity_id: script.kueche_rollo_50
    default: []
  - choose:
      - conditions:
          - condition: state
            entity_id: binary_sensor.balkon_fenster_links
            state: 'off'
          - condition: state
            entity_id: input_boolean.sleepmode_living
            state: 'on'
        sequence:
          - data: {}
            entity_id: script.balkon_rollo_runter
      - conditions:
          - condition: state
            state: 'off'
          - condition: state
            state: 'off'
        sequence:
          - data: {}
              entity_id: script.balkon_rollo_50
    default: []
  - data: {}
    entity_id: script.wohnzimmer_rollo_runter
  - choose:
      - conditions:
          - condition: state
            entity_id: sensor.window_bathroom_open_check
            state: geschlossen
        sequence:
            data: {}
            entity_id: script.badezimmer_rollo_runter
      - conditions:
          - condition: state
            state: offen
        sequence:
            data: {}
            entity_id: script.badezimmer_rollo_50
    default: []
  - data: {}
    entity_id: script.schlafzimmer_rollo_runter
  - data:
      option: Geschlossen
    entity_id: input_select.rollo_stand
    service: input_select.select_option
  - choose:
      - conditions:
          - condition: state
            entity_id: input_boolean.sleepmode_workingroom
            state: 'on'
        sequence:
          - service: script.arbeitszimmer_rollo_runter
      - conditions:
          - condition: state
            entity_id: input_boolean.someone_in_workingroom
            state: 'off'
        sequence:
    default: []
mode: single
