Sun Horizon Elevation Sensor Help
I have the below binary sensor set up so that if it’s ‘ON’ - my light automations will run.
If OFF - light automations don’t run.
template:
  - binary_sensor:
      - name: light_automation_running
        state: >
         {% set use_sun = is_state('input_boolean.light_automation_times_use_sun', 'on') %}
            {{ (now() <= today_at(states(iif(use_sun, 'sensor.sun_next_rise', 'input_datetime.lights_automation_lights_auto_on_before'))) or
                now() >= today_at(states(iif(use_sun, 'sensor.sun_next_set', 'input_datetime.lights_automation_lights_auto_on_after'))) )}}
        icon: >
          {% if is_state("binary_sensor.light_automation_running", "on") %}
            mdi:lightbulb-group
          {% else %}
            mdi:lightbulb-group-off
          {% endif %}
This is connected to an input boolean which I can turn on to the the Sun Rise/Set times to turn ON/OFF the light automations.
So if the the Boolean is on, I manually set the times, otherwise it uses the sun rise/set times.
I’m now wanting to move this over to do two new functions
  1. a new ‘Input Selector’ - to select what I want to trigger the light automations
  • Sun Rise/Set Times (as above)
  • Sun Elevation
  • Manual Times (as above)
  1. The ‘Sun Elevation’ - To be able to adjust at what elevation
Input Selector
input_select.light_automation_trigger
Sun Elevation
input_number.light_automation_times_elevation
I’m struggling on
  1. Converting the above code to look at the drop down list, rather than a on/off
  2. How to set the elevation number.
If you look in the developer tools, you’ll see that the state of an input_select is the selected item
Therefore, you can do something like
{% if is_state("input_select.my_condition", "Sun elevation") %}
   {# blabla bla #}
{% elif is_state("input_select.my_condition", "Sun Rise/Set Times") %}
   {# blabla bla #}
{% else %]
   {# blabla bla #}
{% end if %}
To “set the elevation number”, you just use your input_number in a card
To get the elevation, you use the state_attr function.
{% if state_attr('sun.sun',' elevation') < input_number.my_configuration %}
Thanks for this!
I had this in mind, just needed a steer.
Here is the full sensor if anyone is interested.
template:
  - binary_sensor:
      - name: light_automation_running_new
        state: >
            {% if is_state('input_select.light_automation_trigger', 'Manually Set (Start - Stop)') %}
                {{ now() <= today_at(states('input_datetime.lights_automation_lights_auto_on_before')) or
                now() >= today_at(states('input_datetime.lights_automation_lights_auto_on_after')) }}
            {% elif is_state('input_select.light_automation_trigger', 'Sun Rise/Set') %}
                {{ (now() <= today_at(states('sensor.sun_next_rise')) or  now() >= today_at(states('sensor.sun_next_set')) )}}
            {%  elif is_state('input_select.light_automation_trigger', 'Horizon Elevation') %}
               {{ state_attr('sun.sun','elevation') < states('input_number.light_automation_times_elevation') |float }}
            {%  elif is_state('input_select.light_automation_trigger', 'LUX') %}
               {{ states('sensor.esp32_bedroom_lux') < states('input_number.lux') }}
            {% endif %}
        icon: >
            {% if is_state('binary_sensor.light_automation_running_new', 'off') %}
            {% elif is_state('input_select.light_automation_trigger', 'Manually Set (Start - Stop)') %}
                mdi:emoticon-cool
                mdi:sun-clock
                mdi:theme-light-dark
               mdi:brightness-percent
            {% endif %}
Final thing I’m trying to do, is have a custom icon for each state…
IF OFF = mdi:lightbulb-group-off
IF ON AND USING;
Manual Set (Start - Stop) = mdi:emoticon-cool
Sun Rise/Set Times = mdi:sun-clock
Sun Elevation = mdi:theme-light-dark
LUX = mdi:brightness-percent
EDIT:
Code above updated for the icon
