"Sun tunnel" lighting, have indoor lights match outdoors?
Search has been fruitless but I can’t believe I’m the first to try this: I have a dark room I’m trying to make feel more naturally lit during the day (basically the digital equivalent of a “sun tunnel”). I have a hue light strip, the goal is to have the strip:
  • Auto-adjust brightness based on outdoor brightness
  • Auto-adjust color temperature based on time of day
The reason adaptive lighting isn’t enough on it’s own is because on cloudy/darker days it still goes full-bore with the brightness which feels artificial.
I’ve got "illuminance sensor" (which apparently incorporates weather data) installed and “working”, but it outputs a “lx” reading (0-12,000), and I need to translate that somehow to brightness (1-255) before I can have it match brightness.
  • 255 brightness if over 9k Lux
  • Otherwise, adjust one “brightness” for every X Lx units, down to zero.
Any ideas?
You could use an ESP with a color sensor pointed at the outside sky, which would give you RGB values that can be processed and sent to the light.
You could for example use this: TCS34725 RGB Color Sensor — ESPHome
Well, as a template you could work the maths so that 9,000 / X = 255, and then it will scale linearly.
Call X 35.29 and you’ll be close enough, and use a max of 255:
{{ min(states('sensor.light_level')|float(9000)/35.29,255) }}
Thanks, this is the part that’s beyond me (the programming, not the math). Where could I put this? In the “brightness” section of a script?
Yes, something like:
- service: light.turn_on
    entity_id: light.petunia
    brightness: "{{ min(states('sensor.light_level')|float(9000)/35.29,255) }}"
This was perfect, thanks!
