Hi, i’m new here, i trying tò setup a manual sunrise/sunset for my gf’s father who’s a canary breeder and nerds tò shorten/lenghten the days by creating and artificiali sunrise and sunset
Toghether with chatgpt i set up some variables in configuration, and then set up this automation:
`- alias: “Sunrise and Sunset Simulation”
description: “Gradually adjusts brightness to simulate sunrise and sunset.”
mode: restart # Ensures the automation restarts if triggered while still running
# Trigger for sunrise simulation based on manual input time
value_template: “{{ states(‘sensor.time’) == states(‘input_datetime.alba_orario’)[0:5] }}”
# Trigger for sunset simulation based on manual input time
value_template: "{{ states('sensor.time') == states('input_datetime.tramonto_orario')[0:5] }}"
- choose:
# Sunrise Simulation
- conditions:
- condition: trigger
sequence:
# Define variables for duration, step count, and brightness increment
- variables:
total_duration: “{{ states(‘input_number.alba_durata’) | int * 60 }}” # Convert minutes to seconds
step_count: 50 # Number of brightness steps
brightness_increment: “{{ 255 / step_count }}” # Increment per step
step_duration: “{{ total_duration / step_count }}” # Duration per step
# Turn on the light at the lowest brightness
- service: light.turn_on
entity_id: light.e27_2018_philips_pantografo
brightness: 1
# Gradually increase brightness over the specified duration
- repeat:
count: "{{ step_count }}" # Repeat for the specified number of steps
sequence:
brightness: "{{ [state_attr('light.e27_2018_philips_pantografo', 'brightness') | int(default=1) + brightness_increment | int, 255] | min }}"
transition: "{{ step_duration | int }}"
- delay:
seconds: "{{ step_duration | int }}" # Wait for the transition to complete before next step
# **Sunset Simulation**
- conditions:
sequence:
# Define variables for duration, step count, and brightness decrement
- variables:
total_duration: "{{ states('input_number.tramonto_durata') | int * 60 }}" # Convert minutes to seconds
brightness_decrement: "{{ 255 / step_count }}" # Decrement per step
step_duration: "{{ total_duration / step_count }}" # Duration per step
# Gradually decrease brightness over the specified duration
- repeat:
sequence:
brightness: "{{ [state_attr('light.e27_2018_philips_pantografo', 'brightness') | int(default=255) - brightness_decrement | int, 0] | max }}"
- delay:
# Turn off the light completely at the end of the sunset simulation
- service: light.turn_off
entity_id: light.e27_2018_philips_pantografo`
Which does the job, but in the log the seem tò not shut down (It stops dimming the lights, but in the log It shows as ongoing even After hours). Me and chatgpt can’t seem tò find why
Can you spot anything?
Thank you
