Supervisor 249 update makes my system unsupported
Will it work to make a simple bash script with all the commands… So when disconnect from Pi and after the nmcli command wifi will up again.
I don’t want to move my Rpi from location to my router just to connect to a cable for a short moment…
Yeah i think it will…
Maybe something like this:
#!/bin/bash
execute() {
	sudo systemctl disable dhcpcd
	sudo systemctl stop dhcpcd
declare -fxr execute
timeout 10 bash -ce 'execute'
sudo nmcli device wifi con "YOUR SSID" password "PASSWORD"
@0kk0
It didn’t work for me, so add UTP cable into it. Logged in and saw that my wifi device not worked.
Dit follow steps below and after I got my wifi back did a full reboot of system (not only HA) and wifi was running. In HA I see my system is supported again :slight_smile: thanks anyway for the assistance!
root@hassio: nmcli d
DEVICE       TYPE      STATE        CONNECTION
eth0         ethernet  connected    Wired connection 1
wlan0        wifi      unavailable  --
docker0      bridge    unmanaged    --
hassio       bridge    unmanaged    --
veth12dccf7  ethernet  unmanaged    --
veth14516b6  ethernet  unmanaged    --
veth3a849b5  ethernet  unmanaged    --
veth41ec173  ethernet  unmanaged    --
veth619f409  ethernet  unmanaged    --
veth6a99bfc  ethernet  unmanaged    --
veth72e3982  ethernet  unmanaged    --
veth7ba083d  ethernet  unmanaged    --
vethe959221  ethernet  unmanaged    --
vethf60ef52  ethernet  unmanaged    --
vethfe8034c  ethernet  unmanaged    --
lo           loopback  unmanaged    --
root@hassio: nmcli r wifi on
root@hassio: nmcli d wifi list
IN-USE  SSID  MODE  CHAN  RATE  SIGNAL  BARS  SECURITY
root@hassio: sudo wpa_cli -i wlan0
wpa_cli v2.8-devel
Copyright (c) 2004-2019, Jouni Malinen <[email protected]> and contributors
This software may be distributed under the terms of the BSD license.
See README for more details.
Interactive mode
<3>CTRL-EVENT-SCAN-STARTED
<3>CTRL-EVENT-SCAN-RESULTS
<3>WPS-AP-AVAILABLE
root@hassio: nmcli dev show wlan0
GENERAL.DEVICE:                         wlan0
GENERAL.TYPE:                           wifi
GENERAL.HWADDR:                         MY_MAC_ADDRESS
GENERAL.MTU:                            1500
GENERAL.STATE:                          30 (disconnected)
GENERAL.CONNECTION:                     --
GENERAL.CON-PATH:                       --
root@hassio: nmcli dev wifi list
        MY_SSID     Infra  12    540 Mbit/s  65      ââ
        â_  WPA1 WPA2
        MY_SSID_1  Infra  40    540 Mbit/s  65      ââ
        â_  WPA1 WPA2
        MY_SSID_2  Infra  100   540 Mbit/s  62      ââ
        â_  WPA1 WPA2
root@hassio: sudo nmcli device wifi con "SSID" password "PASSWORD"
Device 'wlan0' successfully activated with '04016a83-XXXX-XXXX-XXXX-30b6aec6f000'.
root@hassio:~# nmcli dev status
wlan0        wifi      connected  MY_SSID
Nice work!!! :grinning::upside_down_face::+1::+1:
Hi All ! I have simmilar problem, after the supervisor update (to version 2020.10.0) HA displays “You are running an unsupported installation”.
There is an error in the supervisor logs “NetworkManager is not correctly configured”.
The link refers to the documentation https://www.home-assistant.io/more-info/unsupported/network_manager
I made changes as in the documentation, but I still get a message and an error. I use the addon DHCP server if it’s important. IP of HA set to static. Someone help?
docker_version 18.09.8
hassio true
host_os
installation_type Home Assistant Supervised
os_name Linux
os_version 3.10.102
python_version 3.8.6
supervisor 2020.10.0
HA version 0.117.1
I can open 192.168.1.5:8123.
I can’t open https://…duckdns.org:8123
Probably problem is in Network manager. I am not specialist. Please could you give step by step instruction to fix.
I do not have info about IP about hostname, ip, OS in Host System section.
I tried:
curl -Lo installer.sh https://raw.githubusercontent.com/home-assistant/supervised-installer/master/installer.sh
bash installer.sh
Thank you!
