Hi, Running HA on Blue.
Never seen such behavior.- Install->Installing… and nothing happens. Restart doesn’t help.
Operating System and Core cannot be updated. “Update Supervisor first.!”
So what now?
What do your supervisor logs say when you try to update supervisor?
“No logbook events found.”
Maybe the next Supervisor update can solve the issue.
Not sure what you’re looking at but that’s not the supervisor logs. Supervisor logs can be found at Settings → System → Logs. Then click the dropdown in the top right corner and select “Supervisor”.
Now I’ve found the right log and I got an idea. Thank you.
Network issue!
I hope I can solve it.
Thank you. I solved it. It was a problem with my network.
