My supervisor logs are filled with these warnings.
21-03-04 17:35:07 WARNING (MainThread) [supervisor.host.network] Can't update connectivity information: Error: Timeout was reached
Does anyone have an idea what is causing this? I am also noticing errors when I attempt to update integrations/addon or update the core/supervisor itself. The only way to fix it is to restart the homeassistant host and quickly initiate the update after rebooting the system.
I then get this error when I attempt to update the supervisor.
21-03-04 18:20:01 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image homeassistant/amd64-hassio-supervisor with tag 2021.03.4.
21-03-04 18:20:17 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/amd64-hassio-supervisor:2021.03.4 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.03.4&fromImage=homeassistant%2Famd64-hassio-supervisor: Internal Server Error ("Get "https://registry-1.docker.io/v2/homeassistant/amd64-hassio-supervisor/manifests/2021.03.4": Get "https://auth.docker.io/token?scope=repository%3Ahomeassistant%2Famd64-hassio-supervisor%3Apull&service=registry.docker.io": context deadline exceeded").
21-03-04 18:20:17 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed!
21-03-04 18:20:17 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_FAILED - ContextType.SUPERVISOR / None
