Supervisor crashes every night
Running the latest build on a pi3. Not really sure what exactly is causing this to happen because I cannot access the logs. 2 things I had suspected was the Google Drive Backup addon or an automation I have running in my daughter’s room (which runs all night). I had disabled them both individually and simultaneously with no luck. Either way, the only way to resolve the issue is a power cycle, which I’m never keen on. I can still use HA, but when opening the supervisor page, I get a blank screen. I’ve tried restarting via SSH with an error that basically says that there was a problem and that I should check the supervisor.
Just to summarise my questions;
  1. How does one safely restart HA in this scenario?
  2. Is there a way to access the log files to spot the problem?
  3. If someone’s already had this issue in the past, what was the solution?
