Supervisor keeps crashing
I’ve got HA running on a pi3. There’s something somewhere that keeps crashing Supervisor every morning for the last 4 days. The only updates that I’ve made so far is adding a sonoff button to my setup. All the automations I have run via node-red. Apart from that, I’ve just updated HA to the latest version. I cannot seem to figure out what’s causing the error. I’ve tried accessing HA via the command line, but it usually just refuses to work, and the UI hits me with a “This site cannot be reached” after some time.
Today, I finally had some success with access via Command Line and saw this:
Get "http://supervisor/network/info": dial tcp: i/o timeout
I’ve tried running the supervisor logs, with no luck and I’ve tried running the HA core logs too with no luck. It seems my only recourse is to reboot by pulling the plug which I would like to avoid. Has anyone dealt with this before?
Mine is also continuously crashing
