I noticed that HA kept getting restarted randomly. I found the following in the superisor logs:
As you can see below, occasionally the watchdog indicates it found a problem with the home assistant api. The web interface is responsive during this time.
I just installed this on an ubuntu 16 vm just a few days ago. Any thoughts?
Thanks in advance.
18-03-11 00:00:35 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home-Assistant startup!
18-03-11 00:03:55 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-03-11 00:05:36 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home-Assistant startup!
18-03-11 00:08:55 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-03-11 00:10:35 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home-Assistant startup!
18-03-11 00:13:55 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-03-11 00:18:55 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-03-11 00:18:55 INFO (SyncWorker_9) [hassio.docker.interface] Restart homeassistant/qemux86-64-homeassistant
18-03-11 00:23:55 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-03-11 00:23:55 INFO (SyncWorker_4) [hassio.docker.interface] Restart homeassistant/qemux86-64-homeassistant
18-03-11 00:28:55 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-03-11 00:28:55 INFO (SyncWorker_8) [hassio.docker.interface] Restart homeassistant/qemux86-64-homeassistant
18-03-11 00:30:35 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home-Assistant startup!
18-03-11 00:33:55 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-03-11 00:35:36 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home-Assistant startup!
18-03-11 00:38:55 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-03-11 00:40:35 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home-Assistant startup!
18-03-11 00:43:55 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-03-11 00:48:55 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-03-11 00:48:55 INFO (SyncWorker_6) [hassio.docker.interface] Restart homeassistant/qemux86-64-homeassistant
18-03-11 00:53:55 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-03-11 00:53:55 INFO (SyncWorker_0) [hassio.docker.interface] Restart homeassistant/qemux86-64-homeassistant
18-03-11 00:58:55 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-03-11 00:58:55 INFO (SyncWorker_8) [hassio.docker.interface] Restart homeassistant/qemux86-64-homeassistant
18-03-11 01:00:35 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home-Assistant startup!
18-03-11 01:03:55 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-03-11 01:05:34 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home-Assistant startup!
18-03-11 01:08:56 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-03-11 01:10:35 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home-Assistant startup!
18-03-11 01:13:55 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-03-11 01:18:56 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-03-11 01:18:56 INFO (SyncWorker_7) [hassio.docker.interface] Restart homeassistant/qemux86-64-homeassistant
18-03-11 01:23:56 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-03-11 01:23:56 INFO (SyncWorker_1) [hassio.docker.interface] Restart homeassistant/qemux86-64-homeassistant
18-03-11 01:28:56 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-03-11 01:28:56 INFO (SyncWorker_8) [hassio.docker.interface] Restart homeassistant/qemux86-64-homeassistant
