Supervisor Problems
Hello, apparently the Supervisor has been crashing constantly recently (about 1-2 times a week). I still have access to the HA via terminal and can reboot it.
I’m not entirely sure what’s going on in the log either:
e[31m2025-05-01 07:16:13.450 ERROR (MainThread) [aiohttp.server] Error handling request from 172.30.32.1
  File "/usr/local/lib/python3.13/site-packages/aiohttp/client_proto.py", line 93, in connection_lost
    uncompleted = self._parser.feed_eof()
  File "aiohttp/_http_parser.pyx", line 508, in aiohttp._http_parser.HttpParser.feed_eof
aiohttp.http_exceptions.TransferEncodingError: 400, message:
  Not enough data for satisfy transfer length header.
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 510, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 198, in block_bad_requests
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 212, in system_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 280, in token_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 293, in core_proxy
  File "/usr/src/supervisor/supervisor/api/utils.py", line 112, in wrap_api
    msg_data = await method(api, *args, **kwargs)
  File "/usr/src/supervisor/supervisor/api/__init__.py", line 554, in get_addon_logs
    return await self._api_host.advanced_logs(request, *args, **kwargs)
  File "/usr/src/supervisor/supervisor/api/host.py", line 283, in advanced_logs
    return await self.advanced_logs_handler(request, identifier, follow)
  File "/usr/src/supervisor/supervisor/api/host.py", line 255, in advanced_logs_handler
    async for cursor, line in journal_logs_reader(resp, log_formatter):
    ...<15 lines>...
            break
  File "/usr/src/supervisor/supervisor/utils/systemd_journal.py", line 80, in journal_logs_reader
    line = await resp.content.readuntil(b"\n")
  File "/usr/local/lib/python3.13/site-packages/aiohttp/streams.py", line 386, in readuntil
    await self._wait("readuntil")
  File "/usr/local/lib/python3.13/site-packages/aiohttp/streams.py", line 347, in _wait
    await waiter
aiohttp.client_exceptions.ClientPayloadError: Response payload is not completed: <TransferEncodingError: 400, message='Not enough data for satisfy transfer length header.'>e[0m
e[31m2025-05-01 07:16:13.480 ERROR (MainThread) [aiohttp.server] Error handling request from 172.30.32.1
    ...<15 lines>...
            break
    await waiter
e[31m2025-05-01 07:16:13.494 ERROR (MainThread) [aiohttp.server] Error handling request from 172.30.32.1
    ...<15 lines>...
            break
    await waiter
s6-rc: info: service legacy-services: stopping
e[32m2025-05-01 07:16:13.622 INFO (MainThread) [supervisor.misc.scheduler] Shutting down scheduled taskse[0m
e[32m2025-05-01 07:16:13.624 INFO (MainThread) [supervisor.docker.monitor] Stopped docker events monitore[0m
e[32m2025-05-01 07:16:13.625 INFO (MainThread) [supervisor.api] Stopping API on 172.30.32.2e[0m
e[32m2025-05-01 07:16:13.629 INFO (MainThread) [supervisor.hardware.monitor] Stopped Supervisor hardware monitore[0m
e[32m2025-05-01 07:16:13.641 INFO (MainThread) [supervisor.dbus.manager] Closed conection to system D-Bus.e[0m
e[32m2025-05-01 07:16:13.649 INFO (MainThread) [supervisor.core] Supervisor is down - 0e[0m
e[32m2025-05-01 07:16:13.652 INFO (MainThread) [__main__] Closing Supervisore[0m
[05:16:13] INFO: e[32mWatchdog restart after closinge[0m
Exception ignored in: <coroutine object PluginBase.watchdog_container at 0x7f97b6eb50>
  File "/usr/src/supervisor/supervisor/plugins/base.py", line 115, in watchdog_container
    await self._restart_after_problem(event.state)
  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 296, in wrapper
    with job.start():
  File "/usr/local/lib/python3.13/contextlib.py", line 162, in __exit__
    self.gen.throw(value)
  File "/usr/src/supervisor/supervisor/jobs/__init__.py", line 160, in start
    _CURRENT_JOB.reset(token)
ValueError: <Token var=<ContextVar name='current_job' at 0x7fb292a3e0> at 0x7fa89afe40> was created in a different Context
[05:16:14] WARNING: e[33mHalt Supervisore[0m
[05:16:14] INFO: e[32mSupervisor restart after closinge[0m
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[05:25:51] INFO: e[32mUsing udev information from hoste[0m
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[05:25:51] INFO: e[32mStarting local supervisor watchdog...e[0m
s6-rc: info: service legacy-services successfully started
  • Core 2025.4.4
  • Supervisor 2025.04.1
  • Operating System 15.2
  • Frontend 20250411.0
Raspberry Pi 4, 4 GB RAM
Does anyone have similar problems?
Regards,
Michael
The exception suggests some communication problem, but I’m no expert on that. With 4GB of ram it shouldn’t be a memory issue. Disk failure comes to mind, or power problems or both.
If you are running from an sd card, my money is on sd failing. Running HA from SD is like waiting for it to happen.
If you’re running from an ssd powered straight from the usb then it is more likely power. Put a powered usb hub in between.
Anyway, if you have another power adapter that is properly rated, try that too.
I’m using the Raspberry Pi with a 128GB NVME drive. The DIN rail power supply delivers 4 A.
