Supervisor.utils.gdbus - DBus return error: Error: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod:
Issue Description
I see frequent error in my supervisor log as ‘ERROR (MainThread) [supervisor.utils.gdbus] DBus return error: Error: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface ‘org.freedesktop.DBus.Properties’ on object at path /org/freedesktop/NetworkManager/DnsManager’
I started to notice this when I was trying to make the Adguard Addon work on my homeassistant.
Not sure if this error is in way stopping the addon to function as intended.
I dont see any other issue with Homeassistant as of now except the adguard doesnt work. I mean in installs fine, but when I manually try to set the DNS info in my laptop I dont see any stats being recorded.
Appreciate any help with this issue.
Supervisor Log
20-06-01 03:27:31 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-06-01 05:20:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
20-06-01 05:20:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
20-06-01 05:20:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/danielwelch/hassio-zigbee2mqtt repository
20-06-01 05:20:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/hassio repository
20-06-01 05:20:51 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-06-01 05:20:52 INFO (MainThread) [supervisor.store] Load add-ons from store: 70 all - 0 new - 0 remove
20-06-01 05:34:11 INFO (MainThread) [supervisor.host.info] Update local host information
20-06-01 05:34:11 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-06-01 05:34:11 INFO (MainThread) [supervisor.host.services] Update service information
20-06-01 05:34:11 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-06-01 05:34:11 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-06-01 05:34:11 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-06-01 05:34:11 ERROR (MainThread) [supervisor.utils.gdbus] DBus return error: Error: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.freedesktop.DBus.Properties' on object at path /org/freedesktop/NetworkManager/DnsManager
20-06-01 05:34:11 WARNING (MainThread) [supervisor.host.network] Can't update host DNS system information!
20-06-01 05:34:11 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-06-01 07:20:51 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-06-01 07:40:51 INFO (MainThread) [supervisor.host.info] Update local host information
20-06-01 07:40:51 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-06-01 07:40:51 INFO (MainThread) [supervisor.host.services] Update service information
20-06-01 07:40:51 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-06-01 07:40:51 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-06-01 07:40:51 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-06-01 07:40:51 ERROR (MainThread) [supervisor.utils.gdbus] DBus return error: Error: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.freedesktop.DBus.Properties' on object at path /org/freedesktop/NetworkManager/DnsManager
20-06-01 07:40:51 WARNING (MainThread) [supervisor.host.network] Can't update host DNS system information!
20-06-01 07:40:51 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-06-01 08:20:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
20-06-01 08:20:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/hassio repository
20-06-01 08:20:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
20-06-01 08:20:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/danielwelch/hassio-zigbee2mqtt repository
20-06-01 08:20:53 INFO (MainThread) [supervisor.store] Load add-ons from store: 70 all - 0 new - 0 remove
20-06-01 09:17:00 INFO (SyncWorker_10) [supervisor.docker.interface] Stop addon_a0d7b954_adguard application
20-06-01 09:17:03 INFO (SyncWorker_10) [supervisor.docker.interface] Clean addon_a0d7b954_adguard application
20-06-01 09:17:06 INFO (SyncWorker_9) [supervisor.docker.interface] Remove image hassioaddons/adguard-amd64 with latest and 2.4.1
20-06-01 09:17:06 INFO (MainThread) [supervisor.addons.addon] Remove add-on data folder /data/addons/data/a0d7b954_adguard
20-06-01 09:17:06 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-06-01 09:17:06 INFO (MainThread) [supervisor.ingress] Update Ingress as panel for a0d7b954_adguard
20-06-01 09:17:06 INFO (MainThread) [supervisor.discovery] Delete discovery to Home Assistant adguard from a0d7b954_adguard
20-06-01 09:17:06 INFO (MainThread) [supervisor.addons] Add-on 'a0d7b954_adguard' successfully removed
20-06-01 09:17:06 INFO (MainThread) [supervisor.discovery] Discovery 360d17486f7b447599315e7abaf6d8ab message send
20-06-01 09:20:51 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-06-01 09:25:50 INFO (MainThread) [supervisor.snapshots] Full-Snapshot b49bd091 start
20-06-01 09:25:50 INFO (MainThread) [supervisor.snapshots] Snapshot b49bd091 store Add-ons
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Build snapshot for add-on a0d7b954_grocy
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Build snapshot for add-on core_letsencrypt
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Build snapshot for add-on core_samba
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Build snapshot for add-on core_configurator
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Build snapshot for add-on a0d7b954_logviewer
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Build snapshot for add-on core_check_config
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Build snapshot for add-on a0d7b954_portainer
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Build snapshot for add-on core_cec_scan
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Build snapshot for add-on a0d7b954_ssh
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Build snapshot for add-on core_mosquitto
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Finish snapshot for addon core_configurator
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Finish snapshot for addon core_samba
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Finish snapshot for addon a0d7b954_logviewer
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Finish snapshot for addon core_mosquitto
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Finish snapshot for addon core_check_config
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Finish snapshot for addon a0d7b954_ssh
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Finish snapshot for addon core_cec_scan
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Finish snapshot for addon a0d7b954_portainer
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Finish snapshot for addon core_letsencrypt
20-06-01 09:25:50 INFO (MainThread) [supervisor.addons.addon] Finish snapshot for addon a0d7b954_grocy
20-06-01 09:25:50 INFO (MainThread) [supervisor.snapshots] Snapshot b49bd091 store folders
20-06-01 09:25:50 INFO (SyncWorker_3) [supervisor.snapshots.snapshot] Snapshot folder addons/local
20-06-01 09:25:50 INFO (SyncWorker_17) [supervisor.snapshots.snapshot] Snapshot folder homeassistant
20-06-01 09:25:50 INFO (SyncWorker_14) [supervisor.snapshots.snapshot] Snapshot folder share
20-06-01 09:25:50 INFO (SyncWorker_13) [supervisor.snapshots.snapshot] Snapshot folder ssl
20-06-01 09:25:50 INFO (SyncWorker_3) [supervisor.snapshots.snapshot] Snapshot folder addons/local done
20-06-01 09:25:50 INFO (SyncWorker_13) [supervisor.snapshots.snapshot] Snapshot folder ssl done
20-06-01 09:25:50 INFO (SyncWorker_14) [supervisor.snapshots.snapshot] Snapshot folder share done
20-06-01 09:26:13 INFO (SyncWorker_17) [supervisor.snapshots.snapshot] Snapshot folder homeassistant done
20-06-01 09:26:13 INFO (MainThread) [supervisor.snapshots] Full-Snapshot b49bd091 done
20-06-01 09:47:31 INFO (MainThread) [supervisor.host.info] Update local host information
20-06-01 09:47:31 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-06-01 09:47:31 INFO (MainThread) [supervisor.host.services] Update service information
20-06-01 09:47:31 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-06-01 09:47:31 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-06-01 09:47:31 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-06-01 09:47:31 ERROR (MainThread) [supervisor.utils.gdbus] DBus return error: Error: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.freedesktop.DBus.Properties' on object at path /org/freedesktop/NetworkManager/DnsManager
20-06-01 09:47:31 WARNING (MainThread) [supervisor.host.network] Can't update host DNS system information!
20-06-01 09:47:31 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-06-01 11:20:51 WARNING (MainThread) [supervisor.addons.addon] Add-on core_samba new schema is not compatible
20-06-01 11:20:51 WARNING (MainThread) [supervisor.misc.tasks] Add-on core_samba will be ignored, schema tests fails
20-06-01 11:20:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/danielwelch/hassio-zigbee2mqtt repository
20-06-01 11:20:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
20-06-01 11:20:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
20-06-01 11:20:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/hassio repository
20-06-01 11:20:51 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-06-01 11:20:52 INFO (MainThread) [supervisor.store] Load add-ons from store: 70 all - 0 new - 0 remove
20-06-01 11:54:11 INFO (MainThread) [supervisor.host.info] Update local host information
20-06-01 11:54:11 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-06-01 11:54:11 INFO (MainThread) [supervisor.host.services] Update service information
20-06-01 11:54:11 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-06-01 11:54:11 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-06-01 11:54:11 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-06-01 11:54:11 ERROR (MainThread) [supervisor.utils.gdbus] DBus return error: Error: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface 'org.freedesktop.DBus.Properties' on object at path /org/freedesktop/NetworkManager/DnsManager
20-06-01 11:54:11 WARNING (MainThread) [supervisor.host.network] Can't update host DNS system information!
20-06-01 11:54:11 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
System Details
arch x86_64
chassis desktop
dev false
docker true
hassio true
host_os Ubuntu 16.04.6 LTS
installation_type Home Assistant Supervised
os_name Linux
os_version 4.4.0-179-generic
python_version 3.7.7
supervisor 225
timezone Europe/London
version 0.110.4
virtualenv false
