Here in the U.K. when we write out currency it isn’t right aligned like a lot of units are.
E.g. 4.50 £ is not correct - it should be £4.50 when using this particular unit of currency - I think American dollars are the same ($).
If we write currency that isn’t in £ and only in pence then we write it - 74p NOT £0.74 generally, although £0.74 is a whole lot better than 0.74£ or 0.74GBP. It’s really about having options that allow you to style units in the most natural/friendly way for your region I guess as all different.
I know most units come after the number such as C, W, kWh etc.
I can’t be the only one with loads of template sensors that only exist to correct this styling?
