Midea branded AC’s with ESPhome (no cloud)
This ‘generic dupont set’ female-female works nice
can I have a picture of your logic board > adapter ? I’m curious :thinking:
See post 1….still using the same as when i started.
i cut my dupont cables, after i found a fit header plug on some old pcb…but dupont would fit both sides (tip, use super glue to head them together :wink:)
I’m thanking @aceindy @paddy0174 @n1k5y
for patience and helpfulness. I’m totally unready and beefeding but you are continuing to supporting me.
Rebecca
Let us know how things work out! :slight_smile:
Btw. I’m using the exact same components as aceindy, I just pushed the female connectors directly onto the pins (of the A/C and the ESP).
Running for more than half a year without any problems. :wink: Even not updated, as I’m way too lazy to update via FTDI (OTA is not available with my small ESP)…that would mean I need to climb up to the A/C, disconnect and so on. Must wait until the end of summer, when I clean my A/C to shut it down for the winter. :slight_smile:
I tried on a spare esp, and ota works nowadays (only took me a while to actually swap them :thinking:)….i guess the original bins we created with the devs repository was bigger than the main repository is now :nerd_face:
Some ESP-01S and own serial to serial shifter board as come home, so I generated a suited ESPhome config and tried to installing it on the chip using a generic CH340G and a generic PL2303 USB to TTL, with and without the serial/serial shifter board, but ESPhome dashboard failed the installation, refusing the connection.
Perhaps the original ESP-01 USB to TTL is needed?
I’m using this adapter to flash my ESP boards. I have the CH340G as well, but couldn’t get it to work. :wink:
EDIT: @aceindy Just tried to flash OTA, still no joy… :frowning: I’ll test with a stripped down file (only OTA) ad try again. Otherwise I’ll need to check if I can use the logic level shifter with an ESP32 (found one lying around in the garage shop :rofl: :rofl:
@paddy0174 I had to use an empty ESP01 ( as the one in use has too little RAM available)
But with this image i can reflash over and over
I connected the nodeMCU to AC via ESP-01’s logical shifter board and i think it’s found/recognised by the AC’s logic board, because the WI-FI icon on the display lights up 30/40s: as the same time as other ACs mounting the original MIdea key, but HA still not able to manage the “modded” AC (Disimpegno).
Overview Dashboard
immagine
Configuration Entities Dashboard
Configuration Devices Dashboard
Current nodeMCU’s ESPhome configuration
esphome:
  platform: ESP8266
  board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "Flying"
wifi:
  ssid: "Foo"
  password: "Bar"
  manual_ip:
    static_ip: 192.168.1.76
    gateway: 192.168.1.3
    subnet: 255.255.255.0
  ap:
    ssid: "Midea-Disimpegno"
    password: "ddl8nnCpqVCT"
captive_portal:
# UART settings for Midea dongle (required)
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 9600
# Optional (if you want modify settings)
midea_dongle:
  strength_icon: true
# Main settings
climate:
  - platform: midea_ac
    name: Condizionatore Disimpegno    # Use a unique name.
    beeper: true                # Beep on commands.
    visual:                     # Optional. Example of visual settings override.
      min_temperature: 16 °C    # min: 16
      max_temperature: 30 °C    # max: 30
      temperature_step: 0.5 °C  # min: 0.5
    swing_horizontal: true
    swing_both: true
    outdoor_temperature:
      name: "Temperatura Unità Esterna"
    power_usage:
      name: "Consumo Condizionatore Disimpegno"
    humidity_setpoint:
      name: "Umidità Condizionatore Disimpegno"
There are some other items that can be useful for troubleshotting?
:slight_smile: Go to your ESPHome dashboard (in your left pane “ESPHome”):
  • What does the status icon/bar say for your node? Is it “online/offline/unknown status”?
  • If online, press the “LOGS” button for your node.
  • Choose the wireless connection.
  • A pop-up should open, there you have the ESP logs.
  • Post the first 80 to 100 lines from the log. Hint: the log scrolls automatically, if new entries are coming in. Just scroll up in the log window and it will stay at that line. New lines will be added, but it will not scroll automatically.
despite the nodeMCU being online
the logger can’t reach it
INFO Reading configuration /config/esphome/midea-disimpegno2.yaml...
INFO Starting log output from 192.168.1.76 using esphome API
INFO Connecting to 192.168.1.76:6053 (192.168.1.76)
WARNING Initial connection failed. The ESP might not be connected to WiFi yet (Error connecting to 192.168.1.76: [Errno 111] Connection refused). Re-Trying in 1 seconds
in the ESPhome device config i have
# Enable logging
logger:
Is that section incomplete ?
INFO Successfully connected to 192.168.1.76
[20:26:54][I][app:105]: ESPHome version 1.20.4 compiled on Aug 19 2021, 20:24:41
[20:26:54][C][wifi:499]: WiFi:
[20:26:54][C][wifi:359]:   SSID: [redacted]
[20:26:54][C][wifi:360]:   IP Address: 192.168.1.76
[20:26:54][C][wifi:362]:   BSSID: [redacted]
[20:26:54][C][wifi:363]:   Hostname: 'midea-disimpegno'
[20:26:54][C][wifi:367]:   Signal strength: -46 dB ▂▄▆█
[20:26:54][C][wifi:371]:   Channel: 3
[20:26:54][C][wifi:372]:   Subnet: 255.255.255.0
[20:26:54][C][wifi:373]:   Gateway: 192.168.1.3
[20:26:54][C][wifi:374]:   DNS1: (IP unset)
[20:26:54][C][wifi:375]:   DNS2: (IP unset)
[20:26:54][C][uart_esp8266:075]: UART Bus:
[20:26:54][C][uart_esp8266:077]:   TX Pin: GPIO1
[20:26:54][C][uart_esp8266:080]:   RX Pin: GPIO3
[20:26:54][C][uart_esp8266:081]:   RX Buffer Size: 256
[20:26:54][C][uart_esp8266:083]:   Baud Rate: 9600 baud
[20:26:54][C][uart_esp8266:084]:   Data Bits: 8
[20:26:54][C][uart_esp8266:085]:   Parity: NONE
[20:26:54][C][uart_esp8266:086]:   Stop bits: 1
[20:26:54][C][uart_esp8266:088]:   Using hardware serial interface.
[20:26:54][C][logger:189]: Logger:
[20:26:54][C][logger:190]:   Level: DEBUG
[20:26:54][C][logger:191]:   Log Baud Rate: 0
[20:26:54][C][logger:192]:   Hardware UART: UART0
[20:26:54][C][captive_portal:148]: Captive Portal:
[20:26:54][C][ota:029]: Over-The-Air Updates:
[20:26:54][C][ota:030]:   Address: 192.168.1.76:8266
[20:26:54][C][ota:032]:   Using Password.
[20:26:54][C][api:095]: API Server:
[20:26:54][C][api:096]:   Address: 192.168.1.76:6053
[20:26:55][D][midea_ac:072]: TX: query
[20:26:55][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:26:55][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:26:55][D][midea_ac:034]: RX: query frame
[20:26:56][D][midea_ac:072]: TX: query
[20:26:56][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:26:56][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:26:56][D][midea_ac:034]: RX: query frame
[20:26:57][D][midea_ac:072]: TX: query
[20:26:57][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:26:57][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:26:57][D][midea_ac:034]: RX: query frame
[20:26:58][D][midea_ac:072]: TX: query
[20:26:58][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:26:58][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:26:58][D][midea_ac:034]: RX: query frame
[20:26:59][D][midea_ac:072]: TX: query
[20:26:59][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:26:59][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:26:59][D][midea_ac:034]: RX: query frame
[20:27:00][D][midea_ac:072]: TX: query
[20:27:00][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:00][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:00][D][midea_ac:034]: RX: query frame
[20:27:01][D][midea_ac:072]: TX: query
[20:27:01][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:01][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:01][D][midea_ac:034]: RX: query frame
[20:27:02][D][midea_ac:072]: TX: query
[20:27:02][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:02][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:02][D][midea_ac:034]: RX: query frame
[20:27:03][D][midea_ac:072]: TX: query
[20:27:03][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:03][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:03][D][midea_ac:034]: RX: query frame
[20:27:04][D][midea_ac:072]: TX: query
[20:27:04][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:04][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:04][D][midea_ac:034]: RX: query frame
[20:27:05][D][midea_ac:072]: TX: query
[20:27:05][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:05][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:05][D][midea_ac:034]: RX: query frame
[20:27:06][D][midea_ac:072]: TX: query
[20:27:06][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:06][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:06][D][midea_ac:034]: RX: query frame
[20:27:07][D][midea_ac:072]: TX: query
[20:27:07][D][midea_dongle:094]: TX: AA 22 AC 00 00 00 00 00 03 03 41 21 01 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 17 6A
[20:27:07][D][midea_dongle:029]: RX: AA 20 AC 00 00 00 00 00 02 03 C1 21 01 44 00 00 6B 01 00 64 00 00 00 00 00 00 00 00 00 00 00 AD 8B
[20:27:08][D][midea_ac:072]: TX: query
[20:27:08][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:08][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:08][D][midea_ac:034]: RX: query frame
[20:27:09][D][midea_ac:072]: TX: query
[20:27:09][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:09][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:09][D][midea_ac:034]: RX: query frame
[20:27:10][D][midea_ac:072]: TX: query
[20:27:10][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:10][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:10][D][midea_ac:034]: RX: query frame
[20:27:11][D][midea_ac:072]: TX: query
[20:27:11][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:11][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:11][D][midea_ac:034]: RX: query frame
[20:27:12][D][midea_ac:072]: TX: query
[20:27:12][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:12][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:12][D][midea_ac:034]: RX: query frame
[20:27:13][D][midea_ac:072]: TX: query
[20:27:13][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:13][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:13][D][midea_ac:034]: RX: query frame
[20:27:14][D][midea_ac:072]: TX: query
[20:27:14][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:14][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:14][D][midea_ac:034]: RX: query frame
[20:27:15][D][midea_ac:072]: TX: query
[20:27:15][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:15][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:15][D][midea_ac:034]: RX: query frame
[20:27:16][D][midea_ac:072]: TX: query
[20:27:16][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:16][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:16][D][midea_ac:034]: RX: query frame
[20:27:17][D][midea_ac:072]: TX: query
[20:27:17][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:17][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:17][D][midea_ac:034]: RX: query frame
[20:27:18][D][midea_ac:072]: TX: query
[20:27:18][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:18][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:18][D][midea_ac:034]: RX: query frame
[20:27:19][D][midea_ac:072]: TX: query
[20:27:19][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:19][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:19][D][midea_ac:034]: RX: query frame
[20:27:20][D][midea_ac:072]: TX: query
[20:27:20][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:20][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:20][D][midea_ac:034]: RX: query frame
[20:27:21][D][midea_ac:072]: TX: query
[20:27:21][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:21][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:21][D][midea_ac:034]: RX: query frame
[20:27:22][D][midea_ac:072]: TX: query
[20:27:22][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:22][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:22][D][midea_ac:034]: RX: query frame
[20:27:23][D][midea_ac:072]: TX: query
[20:27:23][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:23][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:23][D][midea_ac:034]: RX: query frame
[20:27:24][D][midea_ac:072]: TX: query
[20:27:24][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:24][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:24][D][midea_ac:034]: RX: query frame
[20:27:25][D][midea_ac:072]: TX: query
[20:27:25][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:25][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:25][D][midea_ac:034]: RX: query frame
[20:27:26][D][midea_ac:072]: TX: query
[20:27:26][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:26][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:26][D][midea_ac:034]: RX: query frame
[20:27:27][D][midea_ac:072]: TX: query
[20:27:27][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:27][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:27][D][midea_ac:034]: RX: query frame
[20:27:28][D][midea_ac:072]: TX: query
[20:27:28][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:28][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:28][D][midea_ac:034]: RX: query frame
[20:27:29][D][midea_ac:072]: TX: query
[20:27:29][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:29][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:29][D][midea_ac:034]: RX: query frame
[20:27:30][D][midea_ac:072]: TX: query
[20:27:30][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:30][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:30][D][midea_ac:034]: RX: query frame
[20:27:31][D][midea_ac:072]: TX: query
[20:27:31][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:31][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:31][D][midea_ac:034]: RX: query frame
[20:27:32][D][midea_ac:072]: TX: query
[20:27:32][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:32][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:32][D][midea_ac:034]: RX: query frame
[20:27:33][D][midea_ac:072]: TX: query
[20:27:33][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:33][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:33][D][midea_ac:034]: RX: query frame
[20:27:34][D][midea_ac:072]: TX: query
[20:27:34][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:34][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:34][D][midea_ac:034]: RX: query frame
[20:27:35][D][midea_ac:072]: TX: query
[20:27:35][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:35][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:35][D][midea_ac:034]: RX: query frame
[20:27:36][D][midea_ac:072]: TX: query
[20:27:36][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:36][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:36][D][midea_ac:034]: RX: query frame
[20:27:37][D][midea_ac:072]: TX: query
[20:27:37][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:37][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:37][D][midea_ac:034]: RX: query frame
[20:27:38][D][midea_ac:072]: TX: query
[20:27:38][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:38][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:38][D][midea_ac:034]: RX: query frame
[20:27:39][D][midea_ac:072]: TX: query
[20:27:39][D][midea_dongle:094]: TX: AA 22 AC 00 00 00 00 00 03 03 41 21 01 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 17 6A
[20:27:39][D][midea_dongle:029]: RX: AA 20 AC 00 00 00 00 00 02 03 C1 21 01 44 00 00 6B 01 00 64 00 00 00 00 00 00 00 00 00 00 00 AD 8B
[20:27:40][D][midea_ac:072]: TX: query
[20:27:40][D][midea_dongle:094]: TX: AA 21 AC 00 00 00 00 00 00 03 41 81 00 FF 03 FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00 03 00 37 31
[20:27:40][D][midea_dongle:029]: RX: AA 23 AC 00 00 00 00 00 02 03 C0 00 88 3C 7F 7F 00 00 00 00 00 68 66 0C 00 02 00 00 00 00 00 00 00 00 FA D4
[20:27:40][D][midea_ac:034]: RX: query frame
Sorry, I missed that one. :flushed: Your logger entry must be
logger:
  baud_rate: 0
This disables logging on the stick (that’s what we want). Please add this line, re-flash the board and report back. :wink:
look above. resolved
So it’s finally working? Great to hear! :+1:
Have fun with your locally controlled A/C. :slight_smile:
I think the module is working, but there is an issue in HA configuration…
So it’s still not showing up correctly in HA? :frowning: That’s unfortunate.
The node is working as it should, right?
What is the actual status in HA? Is it still the same as in your pics above?
yeah, no changing status
what do you mean for node?
