I have currently secured my home assistant installation with nginx and client certificates. Unfortunately this means that I can not use the client. And for the first time I miss it, due to the new rfid support.
So is there any way to enable so I can choose the client certificate in the app to use for login?
I did this as well using HA Proxy, but I think the results were a little different. My HA Client on a Samsung S9 with Android 10 still worked, but would prompt me for the client cert about 8 times each time the application was opened.
I’m trying to use client certificates to access my home assistant and make it more secure to extern attacks (security nowadays should be a main concern in hass), but without success by the momment.
I use the addon Nginx Proxy Manager to have access to my HA installation from the outside world, but I don’t know where to put the certificates in the server and how to make it work.
I’ve read several guides, but without success:
My questions are these:
Is there an up-to-date guide anywhere on how to do this work?
