michapr
(Michael)
January 8, 2022, 6:51pm
1
have you an idea when the Z-Way support could be integrated?
home-assistant:add-zwave_me
β Z-Wave-Me:dev
opened 05:34PM - 07 Dec 21 UTC
You are amazing! Thanks for contributing to our project!
Please, DO N⦠OT DELETE ANY TEXT from this template! (unless instructed).
## Breaking change
If your PR contains a breaking change for existing users, it is important
to tell them what breaks, how to make it work again and why we did this.
This piece of text is published with the release notes, so it helps if you
write it towards our users, not us.
Note: Remove this section if this PR is NOT a breaking change.
## Proposed change
Describe the big picture of your changes here to communicate to the
maintainers why we should accept this pull request. If it fixes a bug
or resolves a feature request, be sure to link to that issue in the
additional information section.
## Type of change
What type of change does your PR introduce to Home Assistant?
NOTE: Please, check only 1! box!
If your PR requires multiple boxes to be checked, you'll most likely need to
split it into multiple PRs. This makes things easier and faster to code review.
- [ ] Dependency upgrade
- [ ] Bugfix (non-breaking change which fixes an issue)
- [x] New integration (thank you!)
- [ ] New feature (which adds functionality to an existing integration)
- [ ] Breaking change (fix/feature causing existing functionality to break)
- [ ] Code quality improvements to existing code or addition of tests
## Additional information
Details are important, and help maintainers processing your PR.
Please be sure to fill out additional details, if applicable.
- This PR fixes or closes issue: fixes #
- This PR is related to issue:
- Link to documentation pull request: https://github.com/home-assistant/home-assistant.io/pull/20684
## Checklist
Put an `x` in the boxes that apply. You can also fill these out after
creating the PR. If you're unsure about any of them, don't hesitate to ask.
We're here to help! This is simply a reminder of what we are going to look
for before merging your code.
- [x] The code change is tested and works locally.
- [x] Local tests pass. **Your PR cannot be merged unless tests pass**
- [x] There is no commented out code in this PR.
- [x] I have followed the [development checklist][dev-checklist]
- [x] The code has been formatted using Black (`black --fast homeassistant tests`)
- [x] Tests have been added to verify that the new code works.
If user exposed functionality or configuration variables are added/changed:
- [x] Documentation added/updated for [www.home-assistant.io][docs-repository]
If the code communicates with devices, web services, or third-party tools:
- [x] The [manifest file][manifest-docs] has all fields filled out correctly.
Updated and included derived files by running: `python3 -m script.hassfest`.
- [x] New or updated dependencies have been added to `requirements_all.txt`.
Updated by running `python3 -m script.gen_requirements_all`.
- [ ] For the updated dependencies - a link to the changelog, or at minimum a diff between library versions is added to the PR description.
- [ ] Untested files have been added to `.coveragerc`.
The integration reached or maintains the following [Integration Quality Scale][quality-scale]:
The Integration Quality Scale scores an integration on the code quality
and user experience. Each level of the quality scale consists of a list
of requirements. We highly recommend getting your integration scored!
- [ ] No score or internal
- [ ] π₯ Silver
- [ ] π₯ Gold
- [ ] π Platinum
This project is very active and we have a high turnover of pull requests.
Unfortunately, the number of incoming pull requests is higher than what our
reviewers can review and merge so there is a long backlog of pull requests
waiting for review. You can help here!
By reviewing another pull request, you will help raise the code quality of
that pull request and the final review will be faster. This way the general
pace of pull request reviews will go up and your wait time will go down.
When picking a pull request to review, try to choose one that hasn't yet
been reviewed.
Thanks for helping out!
To help with the load of incoming pull requests:
- [ ] I have reviewed two other [open pull requests][prs] in this repository.
[prs]: https://github.com/home-assistant/core/pulls?q=is%3Aopen+is%3Apr+-author%3A%40me+-draft%3Atrue+-label%3Awaiting-for-upstream+sort%3Acreated-desc+review%3Anone
Thank you for contributing <3
Below, some useful links you could explore:
[dev-checklist]: https://developers.home-assistant.io/docs/en/development_checklist.html
[manifest-docs]: https://developers.home-assistant.io/docs/en/creating_integration_manifest.html
[quality-scale]: https://developers.home-assistant.io/docs/en/next/integration_quality_scale_index.html
[docs-repository]: https://github.com/home-assistant/home-assistant.io
This will for me be the final decision to switch to HA, because of changed some time ago from OpenZWave to Z-Way and would like to have again one system with all integrated features
Thanks!
Michael
I initially used OZW here & left for a different system that had its own integration in addition to Z-Way, I chose their integration but noticed almost none of their users were using Z-Way because the other integration was better. I started coming over hear almost a year ago because zwavejs
now used here is far superior to what I was using.
I really doubt there will be much interest in Z-Way especially since the official HA developers have chosen zwavejs
Of course you are free to start a community integration. There are many good community packages for HA available.
BTW, the Razzberry is supported by zwavejs
, I believe.
michapr
(Michael)
January 8, 2022, 7:31pm
3
As I wrote, there is already a ready pull request online Thatβs why was asking (more to the core team)
OpenZwave is not really more supported, I have used it many many years (about from beginning) - but β¦ (you can read about it in their GitHub).
Z-Way is a certified solution and support most devices and have really good support. That is my experience since some years - many of my friends and former customers are using it
In fact is was abandoned early last year and HA moved to zwavejs
right after that.
PerH
January 25, 2022, 10:52am
5
Z-Way may not be interesting for zwavejs users (is it really as good as z-way though?), but i think there are many potential HA users like me who would consider HA if/when the Z-way integration is in place.
Hope there will be a docker for HA core with this integration for beta testing soon!
michapr
(Michael)
March 3, 2022, 1:48pm
6
itβs available now from version 2022.03 - THANKS!
New Z-Way version will be needed (or you must patch the current latest) for the UUID feature.
