Hi there,
Is there a way to integrate this device (temp + humid sensor with LCD):
with Home Asssistant in case the device is paired with Xiaomi (yeelight) bedside lamp that acts also as a hub for Xiaomi Bluetooth devices? I mean this thing here:
https://www.aliexpress.com/item/New-xiaomi-led-bedside-lamp-mijia-bed-lamp-bedlight-romantic-helping-sleep-bluetooth-wifi-connection-desk/32960246124.html?spm=2114.search0104.3.26.23dc717fYgBLXY&ws_ab_test=searchweb0_0,searchweb201602_1_10065_10068_319_317_10696_10084_453_454_10083_10618_431_10304_10307_10820_10821_10301_537_536_10843_10059_10884_10887_100031_321_322_10103,searchweb201603_52,ppcSwitch_0&algo_expid=cf5be8ca-ae47-41ae-80b0-4abc4d6ce735-3&algo_pvid=cf5be8ca-ae47-41ae-80b0-4abc4d6ce735&transAbTest=ae803_5
Here’s a bit more about it: https://youtu.be/q-VYxZtR-Dg
Normally this device (temp+humid sensor) can be added via HA
component, but I’d like to also have a possibility to have the temperature from it th be available in HA via reading the gateway/hub lamp which is WiFI enabled.
The reason for this support is very simple. Bluetooth range is quite low. Especially within a house and when HA server with its USB-Bluetooth dongle is far away. But pairing it with this gateway lamp could extend the range significantly and cover entire house with 1 or 2 lamps like this.
The dedicated yeelight component
model id
bslamp1
seems not to support this anyhow. The platform mitemp_bt
doesn’t support it either.
Any clues or hints?
Thanks!
