Sureflap Connect - Pet Door
Just for reference the battery level went down to -26% before the flap stopped working.
@benleb Do you think there’d be any chance of ever setting the lock state?
I’d like to be able to setup an automation which sets the cat flap to locked-out so the cats can only get out and not back in when the smoke alarm, which is also in HA, is going off.
@badguy
I should probably not post here, but you can have a look at how I implemented it (my hack work around).
Clone this repo to get a python cli can that set the lock state: https://github.com/tinuva/sure_petcare
I put that into my HA (Supervisor) /config folder
In short, I took the original python sure_petcare and added in the initial work to push commands to surecare, based on the php repo I found.
The only thing I implemented was setLockMode, I didn’t care about setHubLedBrightness nor setEnableCurfew, but I can see how some might want/need setEnableCurfew.
You can test it with the following commands:
  • To auth:
    sp_cli.py --update -e <user> -p <pass>
  • List flaps on your account: (to get the id)
    sp_cli.py ls_flaps
  • Set the lock state. 0 = unlocked 1 = locked_in 2 = locked_out 3 = locked_all
    sp_cli.py set_flap_lock <flap id> <lock_state>
    so example do the following to set locked out: sp_cli.py set_flap_lock 10010101 2
Then to use it, you can look at https://github.com/tinuva/home-assistant-config/blob/master/packages/surepetcare_shell_cmds.yaml
Be sure to replace the flap id with your own.
If you want to use it in a lovelace card, with the above package already as part of your config, you can just use:
entities:
  - entity: input_boolean.petdoor_mode_unlocked
  - entity: input_boolean.petdoor_mode_locked_in
  - entity: input_boolean.petdoor_mode_locked_out
  - entity: input_boolean.petdoor_mode_locked_all
show_header_toggle: false
title: Pet Door Set Mode
type: entities
Has anyone had any luck with the feeders yet other than the battery level? Even any little hacks?
Totally loving the intergration so far, We’ve just purchased 3 feeders and really hoping to get the feed times and feed amounts down if possible? Whilst I’m only new to HA I’m happy to provide outputs where I can :slight_smile:
@benleb anywhere that I can buy you a coffee? Would love to put my support behind this!
I’ve added the sureflap as per instructions but after a restart I only get two binary_sensors, one for each cat, I don’t see any other sensors for hub_status etc. Am I missing something ?
You’ll only be able to see either the door or the battery life, home/away, and if it’s online.
Don’t see that, just home/away. When I add the flap-id to the config the extension quits with an IndexError on [‘Battery’].
Anyone else’s since attribute for each pet’s binary sensor 1 hour behind the actual event?
My system time etc. is all correct, so I’m wondering if this is a timezone related issue?
EDIT
Looks like the ‘since’ attribute has no timezone information attached by design.
    @property
    def device_state_attributes(self) -> Optional[Dict[str, Any]]:
        """Return the state attributes of the device."""
        attributes = None
        if self._state:
            attributes = {
                "since": str(
                    datetime.fromisoformat(self._state["since"]).replace(tzinfo=None)
                "where": SureLocationID(self._state["where"]).name.capitalize(),
        return attributes
This means that I cannot convert it to reflect BST:
{{ state_attr('binary_sensor.pet_sami', 'since') }}
{{ as_timestamp(state_attr('binary_sensor.pet_sami', 'since')) | timestamp_local }}
Since TZ: {{ states.binary_sensor.pet_sami.attributes.since.tzinfo }}
2020-05-10 04:36:41
2020-05-10 04:36:41
Since TZ:
@benleb (apologies for tagging) before I raise this as an issue, am I missing something here in how to convert this to current local time?
EDIT
Raised as issue 35576
The developer been missing for months not sure this integrations is being worked on anymore so I wouldn’t count on anything :frowning:
He’s actually pretty active on Github, so I can only imagine he’s just busy on other projects.
Hope someone can help me …
I cant get it to work ,
File “/usr/src/homeassistant/homeassistant/config.py”, line 780, in async_process_component_config
platform = p_integration.get_platform(domain)
File “/usr/src/homeassistant/homeassistant/loader.py”, line 273, in get_platform
f"{self.pkg_path}.{platform_name}"
File “/usr/local/lib/python3.7/importlib/init.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1006, in _gcd_import
File “”, line 983, in _find_and_load
File “”, line 967, in _find_and_load_unlocked
File “”, line 677, in _load_unlocked
File “”, line 728, in exec_module
File “”, line 219, in _call_with_frames_removed
File “/config/custom_components/sure_petflap/sensor.py”, line 20, in
from .utils import gen_device_id
ImportError: cannot import name ‘gen_device_id’ from ‘custom_components.sure_petflap.utils’ (/config/custom_components/sure_petflap/utils.py)
This integration seems pretty dead…
I have a new issue since HA 0.114
This integration was working fine up to that point…
I get this error
2020-08-12 15:20:41 WARNING (MainThread) [homeassistant.setup] Setup of surepetcare is taking over 10 seconds.
2020-08-12 15:20:48 ERROR (MainThread) [surepy] Can not load data from https://app.api.surehub.io/api/me/start
2020-08-12 15:20:48 ERROR (MainThread) [homeassistant.setup] Error during setup of component surepetcare
  File "/usr/local/lib/python3.8/site-packages/surepy/__init__.py", line 156, in get_data
    response: aiohttp.ClientResponse = await self._session.get(
  File "/usr/local/lib/python3.8/site-packages/aiohttp/client.py", line 504, in _request
    await resp.start(conn)
  File "/usr/local/lib/python3.8/site-packages/aiohttp/client_reqrep.py", line 847, in start
    message, payload = await self._protocol.read()  # type: ignore  # noqa
  File "/usr/local/lib/python3.8/site-packages/aiohttp/streams.py", line 591, in read
    await self._waiter
asyncio.exceptions.CancelledError
  File "/usr/local/lib/python3.8/site-packages/surepy/__init__.py", line 160, in get_data
    _LOGGER.debug("response.status: %d", response.status)
  File "/usr/local/lib/python3.8/site-packages/async_timeout/__init__.py", line 45, in __exit__
    self._do_exit(exc_type)
  File "/usr/local/lib/python3.8/site-packages/async_timeout/__init__.py", line 92, in _do_exit
    raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
  File "/usr/src/homeassistant/homeassistant/setup.py", line 191, in _async_setup_component
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/surepetcare/__init__.py", line 131, in async_setup
    await spc.async_update()
  File "/usr/src/homeassistant/homeassistant/components/surepetcare/__init__.py", line 159, in async_update
    await self.surepy.get_data()
  File "/usr/local/lib/python3.8/site-packages/surepy/__init__.py", line 192, in get_data
    raise SurePetcareConnectionError()
surepy.SurePetcareConnectionError
Can this one - rebooted again and it worked this time…
Must have been a timing issue.
Cheers. :grinning:
With perfect timing SurePet had a brief service outage lasting about 40 minutes across all services.
I nearly posted a warning in this thread just in case someone hit the issue during an upgrade :rofl:
Haha, is this why I received a strange notification saying ‘TEST’ when my cat was asleep beside me? Anyone else get that?
Yep, TEST with the content test 2 :slight_smile:
