Does anybody know of anything I can use to remotely monitor my swimming pool temperature?
Also, I’m not sure if this is even useful to know, but can I somehow monitor the pump flow rate to make sure water is flowing correctly without any blockages, etc?
Re flow rate: I haven’t integrated a proper sensor into the plumbing, but as an approximation I’m monitoring the power draw of the pool pump with a smart switch: if the power draw is decreasing significantly that usually means that the water flow rate has decreased and I need to clean the filter.
