I have happily installed HA with a few add-ons and I am making really good progress customizing it to my liking.
One thing I have not noticed until now that you can swipe between views. At this point that is something I don’t want. I am not sure if it is by default or if I have introduced it with some add-on.
Can someone chime in on this? Is this default feature of homeassistant and can it be disabled?
I just want to use navigate function in user interface.
@Edwin_D Yes, I have your plug-in installed. Would disabling it in HACS completely stop the functionality (for testing) or does it have to be somehow uninstalled. I don’t see option to delete it.
If you select the integration in HACS, there is a remove option in the three dot menu. But only if you installed it trhough hacs. Does it show as downloaded, or available for download?
After you uninstalled it you should restart and clear the browser cache.
for manual uninstall, you should find the folder for the plugin in www/community/ and delete it.
