You can use swipe_amount to decrease the swipe distance, by default is 15% of the screen.
I was able to install and run it on HAOS 15 without issues.
If you still experience problems try uninstalling and installing again the plugin.
It that doesn’t help I’m out of ideas, unfortunately.
In the meantime, can someone else confirm that hass-swipe-navigation is working on HAOS 15 or later?
Hi!
Thanks for your work!
I use the Bubble Cards, and on the sliders there is an exception for swipe navigation. However, I only use the sliders in read-only mode, so I would like to remove that exception. How can I do that? Thanks and regards!
