Switch and Dimmer - 2 entities -> 1 command
Hi everybody! I have a question for you:
i have a strip led connected by two smart device:
  1. smart relay that pilot the power supply 220v - 24v
  2. dimmer 24v - 24v for light intensity
    I know that was better have a TRIAC and a 220v dimmer but now i wan’t buy everything twice.
    My question is: it’s possible pilote this two entities like one, e.g. like a native dimmer lightbulb
    → ON-OFF: switch the status of releay
    → Dimming: change intensity
using a custom entity like this:
thank you so much
can u write an example of integration?
What are your relay and brightness control entity ids?
And what values does the brightness control take?
dimmer
switch
Try this:
# configuration.yaml entry
light:
    lights:
      some_light: # change this to whatever entity_id you want
        friendly_name: "Some Light" # change this to whatever name you want
        level_template: "{{ state_attr('light.zig_dimmer_letto', 'brightness')|int(0) }}"
        value_template: "{{ is_state('light.micromodule_switch_3_lightbulb','on') }}"
        turn_on:
          service: light.turn_on
            entity_id: light.micromodule_switch_3_lightbulb
        turn_off:
          service: light.turn_off
        set_level:
          - service: light.turn_on
              entity_id: light.zig_dimmer_letto
              brightness: "{{ brightness }}"
thank you so much! it works perfectly!
can I create a separate light.yaml file and import it in configuration.yaml to beautify that ?
Sure:
configuration.yaml
light: !include lights.yaml
lights.yaml
  lights:
      turn_on:
      turn_off:
      set_level:
