Switch Automation - FIBARO KeyFob and Single Switch 2
Hello!
I’ve recently got my hands on a FIBARO Single Switch 2 (FGS-213) and a KeyFob (FGKF-601)
I’ve been able to set up some switches/toggles so that from the Front-end I can click and turn the switches on and off which is pretty cool:
The Office Light Switch toggle works fine - when its on, its on, and when its off its off. Even when you manually flip the light switch, the front-end will show that its on or off, which is nice and simple :smiley:
However, what I’m having issues with is integrating the KeyFob to also do the same function. I’ve set up an automation as follows:
- alias: "Office Light On"
  hide_entity: False
  initial_state: off
    platform: event
    event_type: zwave.scene_activated
    event_data:
      entity_id: zwave.fibaro_keyfob
      scene_id: 3
      scene_data: 7680
    service: switch.turn_on
    entity_id: switch.switch
- alias: "Office Light Off"
  hide_entity: False
  initial_state: on
    platform: event
    event_data:
      scene_id: 3
      scene_data: 7740
    service: switch.turn_off
The Entity_ID is “switch.switch” as I haven’t renamed it, but it’s the switch that is working in the image above. On the KeyFob, scene_id: 3 refers to the “X” and the scene_data 7680 and 7740 refer to press and hold respectively, but either of the actions don’t seem to trigger the switch to turn on or off - has anyone else been able to do something similar and/or could lend some advice? :cry:
Thanks in advance!
Fixed. Had to use the homeassistant/turn_on or turn_off service call instead:
  hide_entity: False
  initial_state: on
    platform: event
    event_data:
      scene_id: 3
      scene_data: 7680
    service: homeassistant.turn_on
  hide_entity: False
  initial_state: on
    platform: event
    event_data:
      scene_id: 3
      scene_data: 7740
    service: homeassistant.turn_off
