Switch from Supervised (with MariaDB) to HAOS error
Hi everyone,
The following is the initial situation:
  • Raspberry Pi 5 with Supervised Version
  • MariaDB with approximately 24GB
The system is currently running perfectly, but needs to be migrated to HAOS because the Supervised Version is no longer supported.
I’ve now created a backup and am using Raspberry Pi Imager to restore the new system.
Everything is working fine here, but when I upload the file during the setup process, I get to the selection of components to restore, but then nothing happens for hours.
I’ve also already tested it by completing the setup and then connecting my NAS and then trying to restore the backup from there.
However, I get an error message here that I can’t figure out:
Summary
cont-init: info: running /etc/cont-init.d/udev.sh
[14:18:04] INFO: e[32mUsing udev information from hoste[0m
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[14:18:04] INFO: e[32mStarting local supervisor watchdog…e[0m
s6-rc: info: service legacy-services successfully started
e[32m2025-10-19 14:18:04.847 INFO (MainThread) [main] Initializing Supervisor setupe[0m
e[32m2025-10-19 16:18:04.887 INFO (MainThread) [supervisor.coresys] Setting up coresys for machine: raspberrypi5-64e[0m
e[32m2025-10-19 16:18:04.891 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor Package aarch64-hassio-supervisor · GitHub with version 2025.10.0e[0m
e[32m2025-10-19 16:18:04.891 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-networke[0m
e[32m2025-10-19 16:18:04.988 INFO (SyncWorker_0) [supervisor.docker.manager] Cleanup images: [‘Package aarch64-hassio-supervisor · GitHub’]e[0m
e[32m2025-10-19 16:18:05.166 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initializee[0m
e[32m2025-10-19 16:18:05.168 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2025-10-19 16:18:05.168 INFO (MainThread) [main] Setting up Supervisore[0m
e[32m2025-10-19 16:18:05.281 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2e[0m
e[32m2025-10-19 16:18:05.326 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitore[0m
e[32m2025-10-19 16:18:05.334 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.e[0m
e[32m2025-10-19 16:18:05.334 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.ose[0m
e[32m2025-10-19 16:18:05.334 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1e[0m
e[32m2025-10-19 16:18:05.334 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1e[0m
e[32m2025-10-19 16:18:05.335 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManagere[0m
e[32m2025-10-19 16:18:05.335 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauce[0m
e[32m2025-10-19 16:18:05.335 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1e[0m
e[32m2025-10-19 16:18:05.335 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1e[0m
e[32m2025-10-19 16:18:05.335 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1e[0m
e[32m2025-10-19 16:18:05.490 INFO (MainThread) [supervisor.host.services] Updating service informatione[0m
e[32m2025-10-19 16:18:05.494 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio informatione[0m
e[32m2025-10-19 16:18:05.821 INFO (MainThread) [supervisor.host.network] Updating local network informatione[0m
e[32m2025-10-19 16:18:05.856 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}e[0m
e[32m2025-10-19 16:18:05.886 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 16.2 / BootSlot Ae[0m
e[32m2025-10-19 16:18:05.889 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitore[0m
e[32m2025-10-19 16:18:05.891 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-cli · GitHub with version 2025.09.0e[0m
e[32m2025-10-19 16:18:05.917 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-dns · GitHub with version 2025.08.0e[0m
e[32m2025-10-19 16:18:05.930 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.confe[0m
e[32m2025-10-19 16:18:05.936 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-audio · GitHub with version 2025.08.0e[0m
e[32m2025-10-19 16:18:05.950 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-observer · GitHub with version 2025.02.0e[0m
e[32m2025-10-19 16:18:05.963 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-multicast · GitHub with version 2025.08.0e[0m
e[32m2025-10-19 16:18:05.976 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secretse[0m
e[32m2025-10-19 16:18:05.977 INFO (MainThread) [supervisor.docker.interface] Attaching to Package raspberrypi5-64-homeassistant · GitHub with version landingpagee[0m
e[32m2025-10-19 16:18:05.987 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpagee[0m
e[32m2025-10-19 16:18:05.990 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repositorye[0m
e[32m2025-10-19 16:18:05.990 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/d5369777 repositorye[0m
e[32m2025-10-19 16:18:05.991 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repositorye[0m
e[32m2025-10-19 16:18:05.991 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repositorye[0m
e[32m2025-10-19 16:18:06.150 INFO (MainThread) [supervisor.store] Loading add-ons from store: 81 all - 81 new - 0 removee[0m
e[32m2025-10-19 16:18:06.163 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-onse[0m
e[32m2025-10-19 16:18:06.173 INFO (MainThread) [supervisor.backups.manager] Found 0 backup filese[0m
e[32m2025-10-19 16:18:06.173 INFO (MainThread) [supervisor.discovery] Loaded 0 messagese[0m
e[32m2025-10-19 16:18:06.173 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessionse[0m
e[32m2025-10-19 16:18:06.174 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setupe[0m
e[32m2025-10-19 16:18:06.174 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addone[0m
e[32m2025-10-19 16:18:06.174 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/systeme[0m
e[32m2025-10-19 16:18:06.174 INFO (MainThread) [supervisor.resolution.checks.base] Run check for duplicate_os_installation/systeme[0m
e[32m2025-10-19 16:18:06.191 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addone[0m
e[32m2025-10-19 16:18:06.192 INFO (MainThread) [supervisor.resolution.checks.base] Run check for deprecated_addon/addone[0m
e[32m2025-10-19 16:18:06.192 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/systeme[0m
e[32m2025-10-19 16:18:06.192 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2025-10-19 16:18:06.192 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setupe[0m
e[32m2025-10-19 16:18:06.192 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2025-10-19 16:18:06.192 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not running - setupe[0m
e[32m2025-10-19 16:18:06.244 INFO (MainThread) [supervisor.os.manager] Rauc: slot A - activated slot kernel.0, marked slot kernel.0 as goode[0m
e[32m2025-10-19 16:18:06.250 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.jsone[0m
e[32m2025-10-19 16:18:06.358 INFO (MainThread) [supervisor.addons.manager] Phase ‘initialize’ starting 0 add-onse[0m
e[32m2025-10-19 16:18:06.366 INFO (MainThread) [supervisor.addons.manager] Phase ‘system’ starting 0 add-onse[0m
e[32m2025-10-19 16:18:06.366 INFO (MainThread) [supervisor.addons.manager] Phase ‘services’ starting 0 add-onse[0m
e[32m2025-10-19 16:18:06.368 INFO (MainThread) [supervisor.core] Skipping start of Home Assistante[0m
e[32m2025-10-19 16:18:06.368 INFO (MainThread) [supervisor.addons.manager] Phase ‘application’ starting 0 add-onse[0m
e[32m2025-10-19 16:18:06.376 INFO (MainThread) [supervisor.misc.tasks] All core tasks are schedulede[0m
e[32m2025-10-19 16:18:06.376 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setupe[0m
e[32m2025-10-19 16:18:06.376 INFO (MainThread) [supervisor.docker.interface] Updating image Package raspberrypi5-64-homeassistant · GitHub to Package raspberrypi5-64-homeassistant · GitHub[0m
e[32m2025-10-19 16:18:06.377 INFO (MainThread) [supervisor.docker.interface] Downloading docker image Package raspberrypi5-64-homeassistant · GitHub with tag 2025.10.3.e[0m
e[32m2025-10-19 16:18:06.377 INFO (MainThread) [supervisor.host.info] Updating local host informatione[0m
e[32m2025-10-19 16:18:06.377 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state runninge[0m
e[32m2025-10-19 16:18:06.377 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/systeme[0m
e[32m2025-10-19 16:18:06.380 INFO (MainThread) [supervisor.core] Supervisor is up and runninge[0m
e[32m2025-10-19 16:18:06.380 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/systeme[0m
e[32m2025-10-19 16:18:06.381 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/systeme[0m
e[32m2025-10-19 16:18:06.381 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisore[0m
e[32m2025-10-19 16:18:06.381 INFO (MainThread) [main] Running Supervisore[0m
e[32m2025-10-19 16:18:06.385 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/coree[0m
e[32m2025-10-19 16:18:06.385 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/systeme[0m
e[32m2025-10-19 16:18:06.385 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disk_lifetime/systeme[0m
e[32m2025-10-19 16:18:06.387 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_servere[0m
e[32m2025-10-19 16:18:06.394 INFO (MainThread) [supervisor.host.services] Updating service informatione[0m
e[32m2025-10-19 16:18:06.398 INFO (MainThread) [supervisor.host.network] Updating local network informatione[0m
e[32m2025-10-19 16:18:06.404 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_servere[0m
e[32m2025-10-19 16:18:06.419 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addone[0m
e[32m2025-10-19 16:18:06.420 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/systeme[0m
e[32m2025-10-19 16:18:06.420 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/systeme[0m
e[32m2025-10-19 16:18:06.420 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / Nonee[0m
e[32m2025-10-19 16:18:06.420 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / Nonee[0m
e[32m2025-10-19 16:18:06.420 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2025-10-19 16:18:06.420 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2025-10-19 16:18:06.577 INFO (MainThread) [supervisor.host.manager] Host information reload completede[0m
e[32m2025-10-19 16:18:06.602 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2025-10-19 16:18:06.602 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state runninge[0m
e[32m2025-10-19 16:18:06.602 INFO (MainThread) [supervisor.resolution.fixup] System autofix completee[0m
e[32m2025-10-19 16:19:02.610 INFO (SyncWorker_2) [supervisor.docker.manager] Stopping homeassistant applicatione[0m
e[32m2025-10-19 16:19:03.809 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning homeassistant applicatione[0m
e[32m2025-10-19 16:19:03.822 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant docker now installede[0m
e[32m2025-10-19 16:19:03.831 INFO (MainThread) [supervisor.homeassistant.core] Starting Home Assistante[0m
e[32m2025-10-19 16:19:03.843 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulsee[0m
e[32m2025-10-19 16:19:04.081 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant Package raspberrypi5-64-homeassistant · GitHub with version 2025.10.3e[0m
e[32m2025-10-19 16:19:04.082 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is readye[0m
e[32m2025-10-19 16:19:11.705 INFO (MainThread) [supervisor.host.control] Setting host timezone: UTCe[0m
e[32m2025-10-19 16:19:11.863 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2025-10-19 16:19:11.925 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2025-10-19 16:19:14.379 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2025-10-19 16:19:14.410 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state=‘RUNNING’, offline_db_migration=False)e[0m
e[32m2025-10-19 16:19:14.411 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instancee[0m
e[32m2025-10-19 16:19:14.431 INFO (SyncWorker_7) [supervisor.docker.manager] Cleanup images: [‘Package raspberrypi5-64-homeassistant · GitHub’]e[0m
e[32m2025-10-19 16:19:41.543 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2025-10-19 16:19:41.616 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2025-10-19 16:19:43.573 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2025-10-19 16:19:43.638 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2025-10-19 16:20:19.382 INFO (MainThread) [supervisor.mounts.manager] Creating or updating mount: NAS01e[0m
e[32m2025-10-19 16:20:19.385 INFO (SyncWorker_4) [supervisor.mounts.mount] Creating folder for mount: /data/mounts/NAS01e[0m
e[32m2025-10-19 16:20:19.613 INFO (MainThread) [supervisor.backups.manager] Found 45 backup filese[0m
e[32m2025-10-19 16:20:39.247 INFO (MainThread) [supervisor.backups.manager] Partial-Restore fc3fd757 starte[0m
e[31m2025-10-19 16:24:11.070 ERROR (MainThread) [supervisor.backups.manager] Restore fc3fd757 error
File “/usr/local/lib/python3.13/tarfile.py”, line 2604, in makefile
copyfileobj(source, target, tarinfo.size, ReadError, bufsize)
File “/usr/local/lib/python3.13/tarfile.py”, line 252, in copyfileobj
raise exception(“unexpected end of data”)
tarfile.ReadError: unexpected end of data
File “/usr/src/supervisor/supervisor/backups/manager.py”, line 727, in _do_restore
async with backup.open(location):
File “/usr/local/lib/python3.13/contextlib.py”, line 214, in aenter
return await anext(self.gen)
File “/usr/src/supervisor/supervisor/backups/backup.py”, line 533, in open
self._tmp = await self.sys_run_in_executor(_extract_backup)
File “/usr/local/lib/python3.13/concurrent/futures/thread.py”, line 59, in run
File “/usr/src/supervisor/supervisor/backups/backup.py”, line 524, in _extract_backup
tar.extractall(
path=tmp.name,
members=secure_path(tar),
filter=“fully_trusted”,
File “/usr/local/lib/python3.13/tarfile.py”, line 2355, in extractall
self._extract_one(tarinfo, path, set_attrs=not tarinfo.isdir(),
numeric_owner=numeric_owner,
filter_function=filter_function)
File “/usr/local/lib/python3.13/tarfile.py”, line 2464, in _extract_one
self._handle_fatal_error(e)
File “/usr/local/lib/python3.13/tarfile.py”, line 2458, in _extract_one
self._extract_member(tarinfo, os.path.join(path, tarinfo.name),
set_attrs=set_attrs,
filter_function=filter_function,
extraction_root=path)
File “/usr/local/lib/python3.13/tarfile.py”, line 2547, in _extract_member
self.makefile(tarinfo, targetpath)
File “/usr/local/lib/python3.13/tarfile.py”, line 2596, in makefile
with bltn_open(targetpath, “wb”) as target:
ConnectionAbortedError: [Errno 103] Connection abortede[0m
e[32m2025-10-19 16:24:11.078 INFO (MainThread) [supervisor.backups.manager] Restore fc3fd757 starting stage await_home_assistant_restarte[0m
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
[14:38:24] INFO: e[32mUsing udev information from hoste[0m
After a reboot, everything is back to normal.
Is switching from Supervised to HAOS perhaps not possible at all, or is the problem with Maria DB?
Restore first just home assistant
and then the add-ons one at the time, mariadb as last
I believe hours are what it will take, yes. Would not surprise me that a PI would take a bit to extract that.
Did you run out of space? Did you interrupt it? Is the back-up complete?
Start there maybe.
Hey, after 10 hours the backup was restored. All seems fine.
