Switch media_player only off works
Hi!
i have several switches but in one of them (LG TV on/off) only half of the switch works: turn_off.
turn_on doesnt work.
switch:
    switches:
        television:
          value_template: "{{ is_state('media_player.tv', 'on') }}"
          turn_on:
            service: media_player.turn_on
              entity_id: media_player.tv
          turn_off:
            service: media_player.turn_off
Any idea? thanks!
It could be the TV that is the “limit”.
My TV also has an API (no integration in HA) that I can use to select input and turn off. But I can’t turn on since the API is off when the TV is off.
Same thing with the app that is built for the TV. I can switch off but not on.
I can power it on via command by running:
echo 'on 0' | cec-client -s -d 1
the problem is i cannot mix a switch based ‘template’ and another based ‘command_line’
You could have turn on action be running a script, or won’t that work?
yes. I have a command_on to power it on:
     encender_television:
        command_on: >
         ssh -i id_rsa -o StrictHostKeyChecking=no [email protected] "sudo echo 'on 0' | cec-client -s"
yes… Add this to a script, then add the script to the template media player
Sorry i dont know how. :thinking: Can you give me a hand on this?
I only have my phone so it’s hard to see everything.
Configuration -> Scipts -> add script.
As action you call service to run this command, whatever command it is.
Then in your template media player
turn_on:
  service: script.the_script_you_created
Something like that. It’s hard to test it from the phone.
OK now i understand what you meaning. Sorry was a traslation issue. Thanks!
