how are you turning this switch on? Are you going to switch.hvac_mode_auto and turning that on/off? or are going to input_biolean.frio_calor and flipping that?
Im guessing you are flipping the frio_calor?
if that is right, you shouldn’t be doing this… You should go to automations and create an automation that triggers off the input Boolean and sets the mode depending on the state of the input Boolean.
I agree with armedad but you have two options here:
Option 1- Do what armeded suggests & remove the template switch entirely, and instead create an automation
or, what I feel is the better option:
Option 2- Delete your input_boolean.frio_calor helper, and change your value_template to this:
there is also the question of why do this at all. if it is to expose an easy push button control for the UI, that can be done by directly adding the climate entity and having the tap action set the mode. The benefit of doing this is that you can also display other info more easily, like the target temp, maybe fan status etc.
I do it this way because it is a site that has 8 other thermostats, and I thought with an input_boolean to change them all at once.
That input_boolean also controls which pump should be used depending on whether heat or cool is demanded.
I was thinking of using that input to change the whole system with a single button.
Currently we do it with automations, but I tried to remove automations and use templates to make this task easier.
ah, if you are looking for single switch that sets a bunch and potentially have differing behaviors on them even then input_boolean is a reasonable way to go.
