Switch that activates script independent of state from before
I am trying to make a switch that activates scripts independent of state on the switch from before, but with no luck so far.
The script sends a remote command to my samsung tv.
The problem is that my samsung TV does not seem to update properly in homeassistant (slow, or not at all), so I can`t use that as a value template in a template switch.
I want to use it with Alexa and emulated hue, so I can turn on and off the TV from Alexa.
What I have now is two scripts, “TV on”, and “TV off”. But that is kind of stupid, cause then I have to say: “Alexa, turn off TV off” or “Alexa, turn on TV on”.
I can not use input_boolean either, cause if I turn off or on the TV from my remote, the input_boolean will be in the wrong state, and nothing will happen.
Have anyone a solution for this problem? Thank you.
If you’re using the samsungtv component, add timeout: 30 to the settings. I did that it and it now actually updates.
Thank you. I can see it now works good if I control it from homeassistant, and register “on” from the remote, but does not seem to register “off” from the remote. I have the 2017 model, and have host and mac in my configuration, and port 8001, and timeout: 30
Mine is older, but it does register as off within a couple of minutes.
Ok, mine does not update at all it seems. I see that there is a problem with at least one of the MU-series on the homeassistant page with the samsung component. Don`t know how to install the websocket client on hassio if that is the problem.
Assuming you’re not using HassIO:
  1. SSH to the Pi
  2. sudo su -s /bin/bash homeassistant
  3. Activate your virtual environment (exactly how you do this varies according to how you installed HA)
  4. Type pip3 install websocket-client
thank you, but as I wrote, I am using HassIO :frowning:
Then I’m afraid you’re out of luck until somebody produces a component that includes it.
I use this switch to execute scripts on alexa. Note that the switch doesn’t need to be off for the service turn off to execute the turn off command.
    switches:
      lock:
        value_template: "{% if is_state('switch.teststatus', 'on') %}on{% else %}off{% endif %}"
        turn_on:
          service: homeassistant.turn_on
          entity_id: script.test1
        turn_off:
          entity_id: script.test2
One cludgy solution if it’s safe for the TV is to use a smart plug. You could monitor the power draw on the plug, and use that in your script to determine which command to use.
Thank you, that worked perfectly, don’t know why I didn’t think of that.
