Hey all,
I am setting up an esp8266 that controls power to a led light.
I’ve successfully set up the switch so it can be controlled from HA, but I have a couple of problems:
I’ve connected the led light to D6 (GPIO13), hoping that it would output 5V, but I tested with a multimeter and it only delivers 1.8V - is this expected? is there a way I can make this better?
I’d be happy with the light being dimmer, as long as it doesn’t flicker to the naked eye - which is what happens now (I’m guessing because the esp8266 cannot deliver as much power as the led light requests). So I’m thinking of implementing a switch that, when it is on, then it puts voltage on GPIO13 on and off every 20ms or so - would this be feasible to be implemented on the yaml? and if so, how?
Thanks!
