Hi everyone,
I’m a bit stuck.
I want to control the motion and person sensors (two different sensors) with a regular switch on my Lovelace. They obviously have different values, but I just need to be able to switch between “off” and “normal”. I need a toggle switch for these states.
I’ve found various approaches, from using a switch template to triggering a scene, but I don’t quite understand them.
Both sensors hae these options: high, normal, low, off (normal and off are enough). Both are “select.”.
Could someone please explain it to me? Thanks!
Create an automation with 2 triggers based on the state of your switch.
Use a choose or if/else as an action, then add the following action to tell it what option to select (adjust based on your entity ID).
action: select.select_option
entity_id: select.your_motion_sensor
option: normal
Thank you very much for the solution! For someone searching in the future:
alias: Motion
description: Schaltet Motion- und personensensor scharf.
triggers:
- trigger: state
entity_id: input_boolean.anwesenheit
to: "on"
- trigger: state
to: "off"
conditions: []
actions:
- choose:
- conditions:
- condition: state
state:
- "on"
sequence:
- sequence:
- action: select.select_option
metadata: {}
entity_id: select.garten_wohnzimmer_motion_detection
option: normal
metadata: {}
entity_id: select.garten_wohnzimmer_person_detection
option: normal
- conditions:
- condition: state
state:
- "off"
sequence:
metadata: {}
option: "off"
metadata: {}
option: "off"
mode: single
Lovelace-Button:
cards:
- type: custom:button-card
entity: input_boolean.anwesenheit
show_state: false
styles:
card:
- width: 110px
