After running home assistant in a virtual environment under raspbian, I recently tried installing it as a docker container. After some tweaking, it is starting to run almost as complete as my earlier setup.
I do however have a problem with a zwave switch in the frontend. It is shown with two buttons instead of the one it used to have:
The relevant section in my customize.yaml file reads:
climate.danfoss_z_thermostat_014g0013_heating_1_2:
friendly_name: Living Room S - Thermostat
entity_picture: /local/danfossLCO13.jpg
climate.danfoss_z_thermostat_014g0013_heating_1_3:
friendly_name: Living Room N - Thermostat
Does anyone know what could be causing this?
Thanks in advance.
thanks for the replies.
Have tried again with the following. Still no joy
One main difference is that before when it worked, I wasn’t runnng the lovelace UI but the docker image uses it.
