Switch Zigbee Tuya CL-ZBSEC02 - Setting for button
I’ve just configured this device in Home Assistant via Zigbee Home Automation. I can turn the lights on and off through the app, but if I try using the physical button, the light also turns on and off. How can I change the switch mode from Flip to Button in Home Assistant?
I managed to change this configuration by pairing the switch through the Tuya Smart Life app (and in fact, the light responded correctly to the physical button command). However, when I later re-paired the switch via Home Assistant, it lost that configuration. I believe this setting gets reset every time the device is paired again.
thanks
