Does anyone know why the switchbot app doesn’t even install in Home Assistant Intergrations just get error No unconfigured devices found, I then install node red as an add on in Home Assistant and installed switchbot app in node red, input api token and that doesn’t work either, running Home Assistant on virtualbox in windows 10
All working fine here, assume you have set up Bluetooth ?
Sorry for delay replying, Wire came of my bluetooth adapter.
