Switchbot bots not found anymore
I had a switchbot bot connected to HA, and it worked fine. I recently moved and have now set up my RPi4 again, everything seemed to work. When I wanted to add a new switchbot bot it configured it, but the trigger wasnt working. The log showed the switchbot turned on/off and then became unavailable.
In the switchbot app everything was working. I have restarted and shutdown HA on de RPi4 multiple times, no succes. Then I decided to delete the switchbots and reconnect them after resetting the bots manually. Now they wont even show up in HA. Still in the switchbot app everything is working. I can’t figure it out, did someone have the same problem or any suggestions on how to fix this?
Im running HA core 2023.6.3
I dont know why but its fixed
